12 DISC CD CHANGER MOUNTED IN TRUNK SKIPS
jargarner
Year and Trim: 97 Bonneville SSEi-prev
05 Bonneville GXP-current
Post by jargarner »
Is that common? How do you fix that?
How about has anyone taken out the 12 disc changer and installed and ipod?
lewis26
Year and Trim: 2003 SLE || 51k miles
Re: 12 DISC CD CHANGER MOUNTED IN TRUNK SKIPS
Post by lewis26 »
There has been tons of posts about ipods. a simple scrolling down the audio page would have gotten you the solution you want, along with the search function.
-Mike
J Wikoff
Post by J Wikoff »
Get in there with a qtip moist with rubbing alchohol and clean the lens.
ddalder
Post by ddalder »
I had this happen intermittently. Once it would start to skip, it would be a problem until I power cycled my car. After shutting it down and restarting it was fine again for a few days. I suspect in my case it wasn't a dirty lens because restarting the car would always fix it. GM replaced my CDX under warranty. No problems since.
