2000 ssei p/s issue
kaotikd
Year and Trim: 2000 ssei
2000 ssei p/s issue
Post by kaotikd »
On my 2000 i have a problem with p/s.When it is cold it steers fine when it heats up it seems that it gets hard to steer at idle if i give it some gas it steers fine. Also when i take off the p/s cap it pops like it has pressure built up.
Pontiacdad
Re: 2000 ssei p/s issue
Post by Pontiacdad »
How is the fluid level?
Mine was weak and leaking a bit of fluid, I used Lucas power stop leak and all went back to normal.
http://www.lucasoil.ca/products/product ... Automotive
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
kaotikd
Post by kaotikd »
fluid level seems fine
rrounds
Post by rrounds »
My car at idle(in gear when hot) is hard to turn, the best I can figure is at that low of an rpm the pump does not work very well. Increase the rpm just 75 to 100 over what it is now and it should work like its suppose to. All I do is give it a little(very little) gas and it works just fine. Once you get use to it, you will do it automatically(I don't even think about it now, but I have over 189k on it). :wink:
ROD
2000 SSEI (SOLD)
rods789 at comcast.net
PB 14.474 @ 96.248 PB 60' 2.168
180 therm AEM DRYFLOW Air Filters
3.33 pulley 3" cat back exhaust
custom solid front motor mount
custom 6" (BIG) intake
__WCBF '06, '07, '08, '11 survivor__
