For anyone with the 4T65E and the intermittant, hard shift issue caused by solenoid>
Has anyone experianced a noise [stopped, in gear] that develops only after the hard shifts occur?
My 2000se has done this for some time> done the Sfoam/Lucas fix with no benifit
Noise is a metal/squeek/cage rattle, that iminates from the oilpan/ converter area and as you roll forward in light throttle, noise relates to vehicle speed>>Axles/hubs/ belt-access have been eliminated
Strange thing is, . I can drive for a while and not experiance any hard shifts and have no noise> one or two Hshifts and its back, shut the car off for a 10-15 mins and its gone
Guessing converter or pump, but strange it comes and goes
Others?
Hard shifts, with a twist
CorbinDallas
- SE Member
- Year and Trim: 2000 SE
2000 SE, 17" chromies with 235x55x17 & MXV4+
- Archon
Re: Hard shifts, with a twist
Others may chime in, but the only noise that I recall being reported is whining.
alexcoqui
- Posts like an L36
- Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
I too have the shifting problem. but without the noice. & yes, the problems starts after the transmision gets warm, in my case when Ive been on a traffic jam for a long time it gets the worst.
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
golfyeti
- Posts like an LG3
- Year and Trim: 2000 SSEi
Every available option - Location: Winnipeg, Manitoba
My hard shifts never included the after-rattle you mentioned. I hardly ever get the hard shifts since adding the cooler 180 stat.
However, I am now getting a rattling sound similar to what you described but I am sure that I need a new cat coverter. The rattle is most evident at a stop in gear and when initial accelerating.
You may have two separate problems.
Mark
The Familyman's Trans-Am
Intense 3.4 MPS, Intense FWI, Intense PCM, copper NGKs TR55's, MSD wires, MSD coils, BWD ICM, MagnaFlow High Flow Cat, drilled 180 'stat, solid front mount, Monroe Max Air rear shocks, Moog rear mounts, Moog suspension bushings, cleared front corners, 190,000 miles
- laxmangl
- Posts like an L27
- Year and Trim: 2000 SE, 2008 Trek 3700
Occasionally when mine shifts hard I get a whining sound, but no rattling.
180,000 miles and running smooth
CorbinDallas
- SE Member
Thanks
I've had mine up in the air in gear and noise is from the oilpan/trans area
as it rolls forward, you can hear the squeek,squeek,squeek from that area until it reaches a higher rpm then goes away
:sad5:
:sad5:
sparky
- SE Member
- Year and Trim: Black 2000 SSEi
I too had the whine noise with my 2000 SSEi with the very hard shifts after the tranny warmed up.
I installed the Thrasher shift kit (medium setting) and have driven a week now (drove in Chicago traffic yesterday) and the problem went away. I would highly recommend for anyone with the hard shift problem. I've invested about 125 dollars vs the 600-700 dollars the dealer and tranny shop wanted to change the PCS. Best part is any shadetree mechanic can do this.
Sparky
Sparky
