If anyone has the FSM for the '00 Bonneville, could you post the pinout diagram or wiring diagrams for the radio? I just have the stock cd/tape deck with no XM or cd changer. I am trying to figure out a way to hardwire my Zune to the radio, hopefully by wiring a 1/8" headphone jack into the mix somewhere. Right now I'm just using a cassette adapter and it sounds like crap and makes a constant clicking noise. I've seen the install thread with the iPAC-OEM, and that is what i would like to do, but unfortunately there isn't an accessory for the Zune like that to work with.
I haven't seen a wiring diagram yet, but I was thinking that if I could use the outputs from the tape player or something to feed my music through that I might be able to get it to work that way. I might have to put a blank tape in to get it to turn the tape player feed on but I really have no idea at the moment until I can see what I'm actually dealing with.
'00 radio plug pinout diagram?
- harofreak00
Re: '00 radio plug pinout diagram?
Did you see this?
http://www.pontiacbonnevilleclub.com/fo ... f=13&t=318
The dock'n'lock connector doesn't really leave room to be tapped, the above post is the best way.
00SLE
- Year and Trim: 2000 Bonneville SLE, Black
Thanks. Yeah, that's the post I've been going off of, but the iPAC won't hook up to my Zune unfortunately. If it comes down to it I guess I can cut the plug off of the iPAC and rewire it for a Zune plug. I'm just trying to see what other options I have at the moment.
