Complications after messing with coolant elbows
zuper8
Year and Trim: 96 SSEi- 157K
Post by zuper8 »
Replaced upper plastic coolant elbow last week. Noticed it losing coolant throughout the week, it was coming from the aluminum elbow. Put a new seal on aluminum elbow plus RTV. *dang* thing leaks like a faucet. poke around and notice this
sorry about the crappy pic, but if you can see there's a crack at the bottom of this hole that goes all the way into the inlet.
i thought that was part of the WP but it's the thingy (derrrr) the WP bolts to.
- Rachael
Bob Dillon
Re: Complications after messing with coolant elbows
Post by Bob Dillon »
Looks like J-B Weld time to me.
ETA: You DID use the O-ring, right?
zuper8
Post by zuper8 »
yeah, i put a new o-ring on.
- Rachael
If you can't get that fixed with JB Weld, you are looking at a very expensive repair :(
zuper8
Post by zuper8 »
harofreak00 wrote:If you can't get that fixed with JB Weld, you are looking at a very expensive repair :(
yikes... that's what i'm afraid of. i can't even find the part. i guess it's the front cover.
would jb weld work in an area that gets really hot like that?
- Rachael
tripscarcare95
Year and Trim: 1995 SSei
1987 GN 16K Original
Post by tripscarcare95 »
I have seen JB weld work on a cracked transmission drain plug (over tightend the drain plug on a 5.0 mustang tranny, it cracked the housing, JB weld, and so far so good)
Try it you really have nothing to loose, just rough up the area so the JB can "bite" into the metal.
good luck :wink:
zuper8
Post by zuper8 »
man that crack went back farther than i realized.... put on a nice smooth layer of JB weld after some sanding, but it had to be thin so the pipe would still go in. do people usually glop it on? i might put more on the underside but that's all i can do
- Rachael
tripscarcare95
let the thin set, and maybe goop on a little bit thicker once the first layer has dried, let that cure and fire it up and watch for leaks.
trf_ssei
Year and Trim: 1998 bonneville SSEi
Post by trf_ssei »
my buddy and i broke a chunk out of the cover on his old crown vic the part that the waterpump bolted to and circulated thru. anyways we cleaned it up used a die grinder to bevel the edges and used JB on it and it went 100 000 km about and then blew a rod thru the oil pan. but the JB fix lasted longer than the vehicle did. lol
willwren
Post by willwren »
The only way to do that with JB is remove material first, then fill back in. You have to make it smooth (sanding) or the ring won't seal. I doubt it will work. That aluminum will expand and contract with heat cycles. JB weld will too, but not at the same rate. As they expand and contract at different rates, they will break the bond.
zuper8
Post by zuper8 »
dammit you're right. uuuuugh guess i gotta look for a timing cover. runs to andrew's 96 parting out thread
- Rachael
Bob Dillon
zuper8 wrote:dammit you're right. uuuuugh guess i gotta look for a timing cover. runs to andrew's 96 parting out thread
Know anybody that welds aluminum? A few touches with a TIG oughta do it. I've even seen some aluminum solder that works pretty well.
http://www.durafix.com/
I doubt anyone is gonna be able to weld it for as cheap as I sold the part ($20).
Its going to have to come off the car regardless.
Bob Dillon
harofreak00 wrote:I doubt anyone is gonna be able to weld it for as cheap as I sold the part ($20).
Wouldn't even mess with it if a $20 part is available. :banana:
willwren
Post by willwren »
It's still going to be fairly involved either way. The 92-99 TA mount is a PITA for this job. I'd much rather do it on a 2k.
zuper8
Post by zuper8 »
yeah i'm familiar with the TA mount. although i kind of get some joy out of beating the crap out of it when it won't budge. i'm more worried about the harmonic balancer now.
- Rachael
HB is easy if you have the right puller and the 3- M6x1 80mm bolts
zuper8
Post by zuper8 »
aright ya'll, here's my list of stuff:
timing cover (in the mail, gonna arrive tomorrow, thanks haro!)
timing cover gasket set
HB puller with the m6x1.0 long bolts
24" breaker bar for the HB bolt/ nut/ thingy
strong male friends on retainer
beer
cuss words
am i missing things? ooo, one thing i should prolly get is an inch pounds torque wrench, right? or will i not need that?
- Rachael
Got a socket big enough for the HB bolt? I think its a 24mm
Post by Jrs3800 »
zuper8 wrote:aright ya'll, here's my list of stuff:
beer
cuss words
Ohhhh I see ... I'm not invited... Fine... LOL
24 MM like Andrew said... will you have air tools where you will be working on the car? It will make things much easier.. Being that you will have the front cover off for replacement it will be a good time to replace the timing chain and inspect or replace the timing chain tensioner..
Good Luck Rachael
