how to access passenger side relay/fuse panel
Billha
Year and Trim: 1999 SLE 112,000mi
2002 Park Ave Ultra 88,000mi
Post by Billha »
I set out to replace the fuel pump relay today, but I can't do that because I can't see an obvious way to access the passenger side relay/fuse panel.
I removed the passenger side dash lower panel, and I can see the relay/fuse panel, but how do I access the relays? There's got to be a way to pull the panel down, but I don't see an obvious latch mechanism.
Can anyone tell me how to access it?
Thanks.
JMH1950
Year and Trim: no longer a Bonneville owner
Re: how to access passenger side relay/fuse panel
Post by JMH1950 »
I had a look at mine a few weeks ago and couldn't find any way to easily access it either. I think that when the manual says to take it to the dealer for this item, they mean it.
I suspect that if you recline the passenger seat and lay with your head under the dash with a flashlite in your mouth, you might be able to wiggle your hand in there. Maybe.
wjcollier07 wrote:Darn it John...now you got me thinking mine's not big enough.
2001 F150 a basic six cyl with 5 speed manual trans.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
J Wikoff
Post by J Wikoff »
I take the glove box liner out. It doesn't give you perfect access, but it's better than the alternative.
JMH1950
Post by JMH1950 »
(insert head smacking smile here)
Never thought of that.
Billha
Post by Billha »
J Wikoff wrote:I take the glove box liner out. It doesn't give you perfect access, but it's better than the alternative.
Thanks, I thought about that, but I thought there MUST be a better way. After all, a breaker/fuse panel should have easy access, right?
If nobody else knows if or how to lower the breaker/fuse panel, I'll remove the glove box liner...but I'm hoping there's a way to lower the panel...
J Wikoff
Post by J Wikoff »
I tried with no luck. Maybe I missed something, but when I took what looked to be the only bolt holding it in place, it didn't move much.
Billha
Post by Billha »
The shop manual shows a single mounting bolt somewhere at the top of the panel, but I removed the glove box liner and didn't see that bolt. Also, removal of the glove box liner didn't provide good access to the relay panel. I ended up accessing the relay through the removed glove box liner opening using an IC chip extraction tool to remove the #2 relay, and then carefully installed a replacement using needlenose pliers.
Mental note to GM design engineers: Place the relay/fuse panel in a location that allows serviceability.
J Wikoff
Post by J Wikoff »
Yeah, I used needlesnose pliers too.
93RedSled-SSE
Year and Trim: 1993 SSE (NA)
Post by 93RedSled-SSE »
Just to share what I did... in case you run out of options. This is kind of a weird way to do it, but once you get your hand up in there and try to navigate it might make sense.
  • I was able to remove the relay by feel.
    But then realized I didn't notice the pin alignment. So cursed and used the one brain cell still functioning.
    I unplugged the bottom relay (interior lamps) and ever so carefully keeping the pin orientation, plugged it into the now empty fuel pump relay socket... they are the same, generic relay.
    I could see the bottom relay socket and used the new relay in that one.
Pretty dumb, huh? Well, you do what you have to do.
A big honkin picture of the relay layout.
92BonnevilleSE
Year and Trim: 97 Pontiac GP GT
Post by 92BonnevilleSE »
Thanks for that fuse diagram 93RedSled!!! It helped me locate the relay I need to replace. I couldnt figure out which one it was.
Joe
Rebuilt L36, Silverstar highs/lows and fogs, new brake lines, rotors, calipers, pads, ZZP Exhaust, Projector Headlights, Tinted Tails and Windows.
Mods to come- LED Tails, HID Kit, Top Swap (springtime)
