*dang* rattles
airdvr1227
*dang* rattles
Post by airdvr1227 »
I don't know what you call it but my moonroof shade rattles when it's open. Any ideas?
MadMike
Year and Trim: 2003 Bonneville SSEi
Re: *dang* rattles
Post by MadMike »
mine does too sometimes, its common as far as i know
Miles: 80k - Color: Maroon - Rims: aSa sport CD - Tint: 5% ^-^ - cleared fronts - ebay blue high/lowbeams - custom amber turn signals
247whp301chp321tq - 3.4 MPS - Brian Tuned PCM - FWI w/ 9" K&N - 3/4" TB spacer - Alternator Voltage booster w/ 8ga running wire - SLP Headers/DP - HF Magnaflow Cat - Custom 2.5" Exhaust w/dump cutout - Magnaflow mufflers - 103AL@55 - Beldon Wires - MSD ignition - 1.8 Yella Terra roller rockers - 105# valve springs - custom push rods - locks - retainers - Meisure electric water pump - shift kit - false knock kit -
harofreak00 wrote:If you can't afford the fuel for a premium sucking car, you shouldn't be driving it. Sell it for an N/A.
Re: *dang* rattles
The shade? That I don't know. I know my sunroof rattled a little, I found out two of the screws were loose.
Re: *dang* rattles
It shouldn't rattle at all. It should fit very snug in there and you should have to use some effort to pull it forward and back.
If you want to mess with it, start with the sunroof in the normal position, remove the 4 torx screws and then remove the glass. You should be able to see all 4 clips that hold the shade into place. Are the damaged?
yourgrandma
Year and Trim: '02 SSEi
Re: *dang* rattles
Post by yourgrandma »
My glass rattles like crazy. I've been waiting for halfway warm weather to putz with it.
Re: *dang* rattles
Glass rattle is the 4 torx screws. Get a buddy to watch, and when it's level w/ the roof, tighten them.
yourgrandma
Re: *dang* rattles
Are they just set screws? Just push up o the glass and snug up the screws?
Re: *dang* rattles
they might be tight, but if they're loose, then yes. There's no nut to hold on to, if that's what you mean.
