Well it's probably about time to update this.
I finally got the intake installed and on Friday we finally got the car running.
It started right up with good oil pressure (75 psi) and everything. After fixing a few fuel and transmission leaks we got to take it out for a drive. Everything went great, the transmission was shifting perfectly and the engine ran great except under boost. Whenever I gave it more than 3-5 psi of boost it would start misfiring on cylinder 5 according to my aeroforce. It was basically worthless to give it any boost since it ran so bad.
The car had aftermarket yellow tab coils on it so I switched coils with the coils from my 94 and it seemed like it was better, then I ended up getting proper blue tabs from the junkyard which didn't make much difference.
I ended up driving it back and forth from work and put about 200 miles on it over the weekend. I never really got much into the boost as much as I could help it due to the misfire and I thought I'd let the transmission wear in a little bit more.
Coming home Sunday night though I ran into some guy with a DSM and thought I'd give it some more power. I probably gave it too much power for the way it was running and the misfire got much worse; now it was misfiring under all conditions. Luckily I was only 2 miles from home so I just limped it back home hoping it was just a broken spark plug or something.
This is just after I got home with it:
it wasn't just a spark plug...
The damage includes:
1 broken pushrod
2? bent valves
1 broken spring retainer
1 bad rocker
The cylinders and pistons all seem to be okay though.
I'm hoping the rockers weren't the cause of the damage, but either way they're not making it back in because one of their bearings feels like it has some metal or something in it. Maybe eventually they'll go back in but not for now. I'm extremely upset about all of this since I won't have the higher ratio rockers anymore. If it wasn't anything special before it definitely isn't now. Needless to say I'm not happy about this at all.
However, I don't have time to sit and complain about it because the meet is this weekend and this car is going.
I just pulled 2 more heads off a car in the junkyard and I'm picking up 2 new headgaskets and bolts for it tomorrow. I would've had it going again tonight but none of the parts stores had any gaskets in stock. Luckily I can reuse the LIM gasket and even the supercharger gasket!
as it sits:
This will be running tomorrow night and hopefully going in for an alignment the next morning. White curse be d@**ed this car is going to detroit friday!
