Bolt on records?
Post your vacation driving stories, day at the track, breakdowns, safety issues, driving techniques, unique driving conditions, etc. Discuss 1/4 mile and 0-60 times. STREET RACING STORIES ARE STRICTLY PROHIBITED.
WhiteArrow3800
Re: Bolt on records?
Post by WhiteArrow3800 »
95naSTA wrote:
Ultra Magnus wrote:You do NOT need Springs to run 1.9s.
Depends on the wear of the springs and shift point. To take full advantage you do.
This.
Speedster400
Year and Trim: 1996 Bonneville S/SE
Post by Speedster400 »
An engine or transmission bolts on to the cradle. Thats a bolt on, right??????
Just kidding.
Dave
INFO FOR CONVERTING SE TO SSE BODY HERE=>>http://www.pontiacbonnevilleclub.com/fo ... 39372.html
http://www.pontiacbonnevilleclub.com/fo ... 43633.html
2002 Pro Stock Pontiac Firebird**GM 399 Splayed Valve Engine
1996 Pontiac Bonneville SE/SSE **100% Transformation from SE to SSE Complete**Lowered 2.00inches too**
deano55
Post by deano55 »
2003 SSEi wrote:I believe I'm the Fastest active running car. I went 12.50 @ 108mph with a Tune, GenV IC and 1.9 rockers. It was a true bolt on setup. STOCK cam and heads.
I have added Alum Heads, very large lift cam, and a MP112 Intercooled Supercharger. I don't have numbers as of yet for the new setup
what final drive ratio are you running?
Ultra Magnus
Year and Trim: 2002 Ssei
Post by Ultra Magnus »
It's been awhile, thought I'd revisit this one. Hewdgasket took a crap in march, just got done buttoning it all back up. Added a few things since i was going to be in there. Ported M90, HvTB, 1.9s and LS6 springs, ported front manifold. The coolant in the exhaust took out some of the welds, so next up, will be a 3 inch catback with a few glass packs in place if the res and muffs. Should be a nice new baseline before thr next batch of fun stuff.
The L67, being the torque monster it is, still feels like a 6 in the low revs. I've been thinking of gears to combat this, but people have been saying to play with the part throttle timing. I would like it to be able to climb mountains like my Trans Am does....without downshifting. Would adding part throttle timing and playing with the shift points alow this to happen? With over 300lbs torque, it really shouldn't have to downshift going up hill.
