Hood modification
01bonneSC
Re: Hood modification
It would be hard to make any "scoops" you want if you know how to work metal. A lot cheaper than buying a hood that you are just gonna cut up and waste.
- Adamus Prime
- Year and Trim: 2000 Bonneville SE/SC
if its junk though, its "recycling"
2000 Bonneville (S)SE(i) - L26/L32 "top swap" - VS cam - ported M90 - ZZP 3.4" pulley - ZZP PCM tune - INTENSE FWI - Port Matched intake/exhaust - ZZP Power Log Manifolds - ZZP "Stage 2" Trans - 2 1/2" full exhaust - SLP Muffler - Hubcaps
01bonneSC
If its junk its pretty damaged then.Adamus Prime wrote:if its junk though, its "recycling"
- maroon111993
- Posts like an LG3
- Year and Trim: 1997 Grand Prix GTP
01bonneSC wrote:Id be looking to have heat escape out the back of the hood. Like reverse what you have now. When the '64 gets done, the hood is getting lifted a little at the cowl with some washers or aluminum spacers to extract the heat.
1997 Grand Prix GTP "Black Ice, 'cuz it's slick" - 17" Motegi Racing Rims, Hankook Optimo Performance Tires, 'Big 3' Wiring Upgrade, Weapon R Secret Weapon Intake w/ Ram Air, Larger SuperCharger lines, AutoLite 104's, U-Bend Delete, Resonator Delete, Cat Delete, Turbo Flowmaster Mufflers. 342bhp, 327 lb-ft torque, 9.091 boost psi @ 6,012 rpm.
- maroon111993
- Posts like an LG3
Woah. Old post. Just noticed.
