cold start issues
bonnieslp
Year and Trim: 2002 bonneville sle
1988 Monte Carlo SS
cold start issues
Post by bonnieslp »
have had 1 occasion where my car wouldnt start in negative degree weather had the car towed and scanned the computer no codes pressent and when i tried to start after towing it started and ran just fine every since then has happend to wifes co worker twice same year and model any ideas?
bill buttermore
Re: cold start issues
Post by bill buttermore »
When the temperature drops below 0*F, problems that would not matter much in the summer can prevent your engine from starting. For example:
Corroded or loose battery cables or alternator cable
Corroded or loose grounds for ignition, battery, PCM or fuel pump
Weak battery
Weak alternator
Worn starter
Weak ignition coil
Old spark plugs
Failing plug wires
Contaminated fuel (water present)
Leaking fuel injector
Weak fuel pump
Dirty fuel filter
Dirty idle air control (IAC) valve
Sticking throttle plate
Bad intake air temperature (IAT) sensor
Bad engine coolant temperature (ECT) sensor
High viscosity engine oil
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
Mark Fahey
Year and Trim: 2000 SSEi, 3.4", FWI, Saner HD sway bars,137K
Post by Mark Fahey »
Will it turn over but just not start or is it not turning over or doing so slowly?
Karl
Year and Trim: 2001 SSEi
Post by Karl »
My car turns over VERY slowly when it's extremely cold out and battery is only a year old.
Formerly 95seand78z28
2001 SSEi (L67Heaven) - Swooped, Pullied, Cleared, and Tinted -GONE!
2014 GMC Sierra SLT.
bonnieslp
1988 Monte Carlo SS
Post by bonnieslp »
the car turns over great just no start issues checked the throttle plate,iac,fuel pressure,ect,and just about every thing else all was good probably just bad fuel
bill buttermore
If you suspect water in the fuel, add a couple of bottles of Heet to the gas tank.
