Oil Leak
CJCroel
Year and Trim: 2006 Grand Prix GT
Oil Leak
Post by CJCroel »
I'm pretty much in the dark about this one guys. I haven't been around in a while, but at the same time I haven't driven my car but maybe 1000 miles in the last 4 months due to having a take-home work truck.
I discovered a puddle of oil last night under my car...the puddle is toward the passenger side tire where I always park. Popped the hood and discovered oil near the top of my engine, pooling around the front spark plugs. This is about all I can tell you right now, other than it's holding good pressure and not losing oil very fast (even though I don't drive it a lot I stay on top of the oil level).
Is this a common leak, and how hard is it to fix? I know I really didn't give much detail as to where it's coming from, but that's about all I can see at this point.
Thanks a million guys...
-Chris
2006 Grand Prix GT
Sport Red Met. - L32 Supercharged, Tint, Leather, Heated/Power Seats, Remote Start/Keyless, Dual Climate Control, 17" wheels, 70k miles. Mods to come.
1997 Bonneville SE *Sold*
Dark Yellow-Green Met. - Tint (35% front, 5% rear) - CAI - Aftermarket Keyless/Remote Start - Disabled DRLs - Belden Wires, TR55 plugs - Cleared Corners - Silverstars - 190,591 miles when sold
bill buttermore
Re: Oil Leak
Post by bill buttermore »
Front spark plugs wet with oil --> valve cover gaskets
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
clm2112
Year and Trim: 1990 Bonneville LE
Re: Oil Leak
Post by clm2112 »
:stupid:
The only thing holding oil above the spark plugs is the valve covers. If they are dry on the outside then feel the surface of the head above the sparkplug with oil on it. If it feels slick, then the gasket needs replaced, cause the oil is seeping out the seam between the head and the valve cover. (easy to replace.)
bill buttermore
Re: Oil Leak
You will want to make sure that the oil is not transmission fluid. Sometimes the rubber cooling lines that carry the transmission fluid to and from the radiator can develop a leak and spray fluid on the engine. Such leaks have caused under hood fires, so check out the lines to make sure they are dry when the car is idling.
The most likely source of your leak, as Curt and I have suggested, is failing valve cover gaskets. Read how to fix them here: Change Valve Cover Gaskets
CJCroel
Re: Oil Leak
Post by CJCroel »
It's definitely oil that's leaking, not trans fluid...I appreciate the help!
-Chris
2006 Grand Prix GT
