Toasted my motor. The rebuild pg 3. It's Alive! 12/18 pg. 4
SuperSLE
Year and Trim: sold
Re: Toasted my motor. Now on the rebuild pg 3
Post by SuperSLE »
(In my best Dr. Frankenstien voice) Its alive, Its alive!! woohoo
:drive: The choppyness you hear is an injector 6 circuit problem (found a broken wire in the harness) that I fixed after this video.
2000 SLE
Re: Toasted my motor. The rebuild pg 3. It's Alive! 12/18 pg. 4
Post by Jrs3800 »
Glad to see it :wink:
2000Silverbullet
Post by 2000Silverbullet »
That didn't take too long.
So tell us how was the heater core change? How much of the dash had to come apart?
You replaced all the bottom end bearings. Did you replace the piston rings?
OH2LS
Year and Trim: 2002 Chevrolet Impala LS
Post by OH2LS »
2000Silverbullet wrote:You replaced all the bottom end bearings. Did you replace the piston rings?
Um..... he replaced the motor lol. Got a spare motor and swapped shortblocks.
"3.8 Liters of twisted steel and sex appeal" -schmidty on NAIOA
I've got an '04 CompG. Got a Gen V and an intake...... so far
SuperSLE
Year and Trim: sold
Post by SuperSLE »
Yeah Paul. I got a L36 bottom end and swapped heads, cams, timing set, all covers and intake manifolds, and headers. Engine was low milage from Morad. Now I have an extra block to start working on :twisted: .
I did a write up for the heater core. Hopefully someone will sticky it if they haven't already. I see you have already found it.
2000 SLE
2000Silverbullet
Doh, that's right. It must have been those pics of the disassembled engine that confused me.
It will be good to have a spare rebuilt block on the shelf..............with some forged pistons. :wink:
You driven the car yet? Glad to see you got it back running.
SuperSLE
Year and Trim: sold
Post by SuperSLE »
2000Silverbullet wrote:It will be good to have a spare rebuilt block on the shelf..............with some forged pistons. :wink:
Yeah, and an XPZ cam, 130# springs, double roller, Stage 4 heads....... :laughing3: Yeah, I'll have a good spare.
00Beast wrote:You driven the car yet? Glad to see you got it back running.
Yeah, I drove it to get some lunch today about two miles there and back. Seems to be running very well. :banana:
2000 SLE
radomirthegreat
Year and Trim: 1994 SSEi 1999 SLE
Post by radomirthegreat »
Ah, so that's what progress looks like! Fantastic work so far. I'm not sure if it has been written yet, but am I to believe you're running an L36 shortblock with the 9.5:1 compression rating?
94 SSEi - Project car
99 SLE - Tuned with different parts and such
85 Porsche 944 - Daily driver
68 Chevy C-10 - Free truck! Needs parts.
1994se
Post by 1994se »
Congrats man. I personally would steer clear of rebuilding a previously toasted L67 bottom end as i only know of a few people who have had any luck rebuilding.
http://www.thechicagogarage.org - Now Home of ILGPC
SuperSLE
Year and Trim: sold
Post by SuperSLE »
1994se wrote:Congrats man. I personally would steer clear of rebuilding a previously toasted L67 bottom end as i only know of a few people who have had any luck rebuilding.
Well I think the block is okay. All that needs to be replaced are all the bearings. And then it should be good. It doesn't need to be machined really, but I will probably have it looked at to make sure.
radomirthegreat wrote:Ah, so that's what progress looks like! Fantastic work so far. I'm not sure if it has been written yet, but am I to believe you're running an L36 shortblock with the 9.5:1 compression rating?
That is correct. It is written somewhere but gets lost in the mix. I am pretty excited really to see what it will do with the higher compression. I will have a little less boost, but I think it will produce more power.
2000 SLE
2000Silverbullet
Go real easy on the timing or you will be using your spare block sooner than you want.
SuperSLE
Year and Trim: sold
Post by SuperSLE »
Yeah, don't I know that. Going real easy on it for a while. I am a bit scared to break it again.
2000 SLE
SuperSLE
Year and Trim: sold
Post by SuperSLE »
Well I put about 400+ miles on it yesterday and all ran fairly well. I decided that I had to raise the idle a bit with city driving. It is really annoying when you are sitting at stop lights and it feels like it is misfiring all over the place with the lope. Crappy for city. Fun for track.
I noticed that there is a little more vibration in the engine with the L36 bottom and not so much with the L67 bottom. Could this be the different balance between the L67 balancer and the L36 bottom? How would I balance that back out again if so?
2000 SLE
SuperSLE wrote:Well I put about 400+ miles on it yesterday and all ran fairly well. I decided that I had to raise the idle a bit with city driving. It is really annoying when you are sitting at stop lights and it feels like it is misfiring all over the place with the lope. Crappy for city. Fun for track.
Finding the L36 balancer would be the easiest approach.
1994se
Post by 1994se »
I was just thinking... You do all this work to your wifes DD? what is your car then?
1994se wrote:I was just thinking... You do all this work to your wifes DD? what is your car then?
X2
radomirthegreat
I have been told by the GP community that there is no difference between the L36 and L67 harmonic balancers. This is mostly evidenced by L36 guys going for a 5% overdrive balancer and a properly snouted M90. It's still worth a shot if you think you'd want to get that far into it. Maybe there are slight differences.
What's your new idle RPM?
Post by Jrs3800 »
Off the wall question... was the L36 or L67 flywheel used?
radomirthegreat
Judging from the belt routing, L67.
