Time for a tune
- The Crunge II
- Year and Trim: 1996 SE
Time for a tune
OK well now that all my hard mods are done for now its time for a tune. but i need advise....
If anyone who knows could just fill in the blanks:
Cooling fan #1 turn ON temp: _______ °F / turn OFF: _______ °F
Cooling fan #2 turn ON temp: _______ °F / turn OFF: _______ °F
Desired Rev Limiter: _______________ RPM (max engine RPM)
Desired Idle Speed in Park/Neutral: _______ RPM Cold / _______ RPM Hot
Desired Idle Speed in Gear (auto) : _______ RPM Cold / _______ RPM Hot
Desired TCC engagement vehicle speed: ___________ MPH (stock or +/- MPH)
Optimize part-throttle shift points for:
â–¡ Performance â–¡ Economy â–¡ Towing â–¡ Leave at Stock Settings
Desired FULL-THROTTLE shift points: ____________ ENGINE RPM
1996 SE w/ magnaflow high flow cat, 180* Drilled T-Stat, intense FWI, PLIM, ER Rockers w/stock springs, 1 5/8ths primary pacesetter headers
- 95naSTA
- Year and Trim: 95 SLE
Re: Time for a tune
You could lower the Cooling fan temps 15 degrees to match your thermo.
I'd say 6100 for a rev limiter.
Stock idle. Bumping it up is something you do when cammed.
Stock TTC lock up unless you find its constantly going in and out of lockup when you drive normally. Then just bump it up a few mph.
Stock shifts with a 6k WOT shift point.
What about spark and WOT AF?
- The Crunge II
Re: Time for a tune
They aren't options on the form...
And whats AF?
And whats AF?
- danthurs
- Posts like an L36
- Year and Trim: 1997 Bonneville SSEi
Re: Time for a tune
Here's some of the set points I have. It might be of use to you. If you need anything else just ask and I'll see what I have it set at.
http://www.bonnevillepro.com/forums/vie ... 186&t=7179
Mods, CAI, Gatorback SC belt, 180 deg. thermostat, sparkplugs 2 colder gapped @ .050, 3.1" MPS, intense™ PCM, AeroForce scan gauge, Flowmaster series 80 muffler, 3" Magnaflow cat , INTENSE™ Street/Strip Performance Shift Pak, 1.9:1 roller rockers, Oil Restricted pushrods, CompCam #105 springs, CompCam heavy duty spring retainers and valve locks, 17" wheels, 245/45 FirehawkGT tires,slotted rotors, cermaic pads, Wideband O2, MSD Blaster coils, MSD 8.5mm sparkplug wires, Stainless steel TOG headers, HP tuner, P&P LIM and supercharger, SSIC
Getting ready to install cowled hood, Project on hold!
Objects in mirror are loosing!
- 95naSTA
Re: Time for a tune
Air/FuelThe Crunge II wrote:They aren't options on the form...
And whats AF?
If you're not going to have the spark tables and fueling adjusted I would say it's not worth it.
- The Crunge II
Re: Time for a tune
well hes gonna tweak all that for me.
- The Crunge II
Re: Time for a tune
can stock springs with ER rockers take the rev limiter bump to 6100?
2003 SSEi
- Year and Trim: 2003 SSEi.
LOTS of Mods
Re: Time for a tune
set the limiter there
set the shift points no higher than 5800
- Allmachtige
- Retired Moderator
- Year and Trim: 2009 G8 GT
Re: Time for a tune
Agreed.1993 sle wrote:set the limiter there
My 1->2 shift is 5800rpm and my 2->3 shift is still 5900, which I can tell it too high.
2009 G8 GT - White Hot
415/391
415/391
- 95naSTA
Re: Time for a tune
I don't see rockers or headers in your sig though.Allmachtige wrote:Agreed.1993 sle wrote:set the limiter there
I still say 6k.
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
Re: Time for a tune
right from the sig "ER Rockers w/stock springs"
- Allmachtige
- Retired Moderator
Re: Time for a tune
Even then, 5900 should be fine.95naSTA wrote:I don't see rockers or headers in your sig though.Allmachtige wrote:Agreed.1993 sle wrote:set the limiter there
I still say 6k.
With 1.9's on a 98 I was using an Intense PCM, which has a 2->3 shift of 5900. It would really be up to a dyno.
Keep in mind the trans won't shift right at 5900rpm, it will actually reach between 6000-6200rpm depending on the situation.
415/391
415/391
- The Crunge II
Re: Time for a tune
And a 4T60 will take that?
- Oldsman105
- Posts like a Northstar
- Year and Trim: 2001 Bonneville SSEi
Re: Time for a tune
Mine didn't. I would say 5800 was all my transmisson could take but results may vary.
- 95naSTA
Re: Time for a tune
I was shifting my 60e at 6400 for a little while, bumped it up to 6600 it shifted a handfull of times and then wouldn't shift. Bumped it back down to 6400 shifted for a month maybe then did the same thing. I tried different things like overfilling the trans and an adjustible modulator. It helped but only temporarily.. I did a fluid filter change and it shifted at WOT for the next 3-4 months untill I got into an accident.
So, from someone who use to rev the crap out of the 4t60, I think you can make 6k shifts last if you don't beat on it all the time.
- The Crunge II
Re: Time for a tune
hmm that could be a problem for me... Im a WOT addict lol
- 2000Silverbullet
- Retired Gearhead
Re: Time for a tune
I had Intense bump my 1-2 and 2-3 shift points to 6200 rpm. It actually commands at 5950 and shifts at 6150 rpm.
The stock 65 trani is rated to 6500 rpm in 1st gear and 6200 rpm in 2nd and 3rd......good luck getting there in 4th.
- danthurs
- Posts like an L36
Re: Time for a tune
I have
1-2 5800
2-3 5900
3-4 6000
I'll shift from 1 to 2 between 6000 and 6100
1-2 5800
2-3 5900
3-4 6000
OH2LS
- Year and Trim: 2002 Chevrolet Impala LS
Re: Time for a tune
FWIW, the PCM shift points are gauged to shift at a particular MPH, not RPM. So if conditions vary slightly you will see it shifting at slightly different RPMs. Right now mine shifts in the vicinity of 6300-6400 rpm. I have Comp 105 springs and a GT1 cam though. I could probably go a bit higher with it but I don't have a double roller in there for higher rate springs.
"3.8 Liters of twisted steel and sex appeal" -schmidty on NAIOA
I've got an '04 CompG. Got a Gen V and an intake...... so far
