Can't get it started
driverjohn2005
Year and Trim: Member since Jan 2003
Post by driverjohn2005 »
I tried jumping Gravenge for a good 15 minutes tonight with no luck. She has sat for a while now; but have NEVER had this much of an issue. I have a fresh Optima battery and alternator as of last year. The starter is clicking so it's trying to start...
Suggestions anyone?
-driverjohn2005
"Gravenge" -1992 Pontiac Bonneville SSEi- Sold 4/29/12 to "myfirstbonnie"
Current Rides: 2015 Mitsubishi Outlander Sport GT AWD & 1999 Ford F-150 Lariat 4x4 SuperCab
BillBoost37
Year and Trim: 00 Regal
Re: Can't get it started
Post by BillBoost37 »
Disconnect the battery and charge it at 2amps for 24 hours straight. If anything will revive it that will do the trick. It's part of the GM FSM's and recommended for a partially or fully dead battery.
97 Ei
97 GS
98 GS
Are you sure it isn't the relay clicking? The starters don't click, they just start or don't start. This will happen if there isn't enough juice to start the car. You might not have been getting a good connection at the jump.
velvetdreams21
Year and Trim: 1994 SSEi
Post by velvetdreams21 »
harofreak00 wrote:Are you sure it isn't the relay clicking? The starters don't click, they just start or don't start. This will happen if there isn't enough juice to start the car. You might not have been getting a good connection at the jump.
Also make sure the battery cables are tight. A week ago my car wasnt starting but I heard clicking, the radio played real loud with the lights on no problem so I thought the starter was messed up again. Sounded weird to me to find out thats why my car wasnt starting but they were tightened and it started right up
1994 Bonneville SSEi
Stereo: Jensen Cd Deck, two 12" 600 watt Visonik subs, 6X9 Kicker "KS SERIES" 3-Way 300 Watts (for now)
Mods: 180* T-stat, Red wire loom, and Red painted strut bar.
Interior: Blue CD Neon, Chrome racing pedals, Custom painted dash
Exterior: Tinted Taillight
LakevilleSSEi
Recognized Vendor
Recognized Vendor
Year and Trim: 96 Audi A6 Quattro
Location: Lakeville, Minnesota =MWBF '05 SURVIVOR= =CEBF '06 SURVIVOR= =August '06 COTM=
Post by LakevilleSSEi »
Startes will click when the starter pushes the gear out to the flywheel, but not enough to turn the motor.
Try what Bill said, pull the batterry and charge it for a day or two at a 2 amp trickle charge...you battery and alternator will love you for it.
1995 SSEi - Traded to Adam Marcum
1998 SLE - Traded for my Dodge
2003 Dodge Ram 2500 Laramie - Sold
1996 Audi A6 Quattro
I used to be cool......Then I traded my Bonne's.
Cooey
Year and Trim: 1996 SSEi
Post by Cooey »
Another thing to try is to ensure that the starter's bolts are tight to the motor; my were loose which affected the grounding of the starter and then I had issues like yours.
1996 SSEi, Traction TA's H, Belden, NGK and {Ultra} Silverstars hi low and fogs, 90.5C stat
driverjohn2005
I don't have a battery charger but will probably get one this weekend. Thanks for the imput everyone. I appreciate it!
-driverjohn2005
ColdScrip
Year and Trim: 1992 Pontiac Bonneville SSEi - L67 Series 1 - 131,000 Miles.
Post by ColdScrip »
I will add that my starter would click and it sometimes took many clicks to actually start the car. Until finally it wouldn't start no matter what. It did turn out to be a bad starter. It lasted with the click problem for about a year.
2000Silverbullet
Post by 2000Silverbullet »
You need a Battery Tender John.
I have one always connected to my stored battery.
The battery will discharge after a few months of sitting.
Billha
Year and Trim: 1999 SLE 112,000mi
2002 Park Ave Ultra 88,000mi
Post by Billha »
Sounds like it could be a weak battery, corroded or loose battery cables, or a bad starter. I'd start by using a fully charged battery and checking the battery cable connections.
driverjohn2005
Gravenge is happily back in the garage now. I did a charge all last night and today. INSTANTLY fired off tonight :twisted:
Had to just listen to the sound system for a bit. I miss having a decent system in the vehicle I drive (aka; the Explorer's system SUCKS!)
Thanks guys! :)
-driverjohn2005
