remote fob
Leejr57
Year and Trim: 1995 bonneville SE
remote fob
Post by Leejr57 »
I recently got a different fob for my wife's 95 bonneville SE. I can't find anything here on how to program the new fob. Any help would be appreciated. I thought I saw it here earlier,but now I can't seem to find it.
Re: remote fob
Turn the ignition off
Connect a jumper wire between pins 4 & 8 on the Data Link Connector
When the jumper connection is made, the power locks should respond by locking and unlocking
Simultaneously press both the lock and unlock buttons on the first transmitter
Hold for a second, and then release
If the programming was successful, the locks should lock and then unlock.
Repeat steps 4-6 for additional transmitters
Disconnect the jumper wire
Verify the operation of each transmitter
Leejr57
Re: remote fob
Post by Leejr57 »
I just tried to set the remote with your instructions, but nothing happened. Do you have an illustration of this procedure? Pin 4 has a connector while Pin 8 does not seem to have one :???:
Re: remote fob
Post by Jrs3800 »
Not a Great Pic... But iirc Pin 8 will be the bottom row on the left..
On this you'll see the Keyless Pin and pin 8 which is Ground..
Haro is this correct?
Re: remote fob
Guest
Year and Trim: n/a
Re: remote fob
Post by Guest »
guys 1995's are different than 96 and newer...
go in your trunk and pull back the carpet on the passenger side quarter panel
look up by the antenna area
find the wire that is not connected to anything..... green I think
ground out that wire and your locks should lock than unlock
when that happens hit the trunk button on your new key fob
than your lock button
once you confirm the key fob is working your locks... your done
un-ground the wire and tuck it back up where you found it
oh wait..this was for my 95 Gutlass
never mind
Todd............
Leejr57
Re: remote fob
Post by Leejr57 »
Perfect!! You guys are terrific! My wife is happy,finally,for a few seconds! =D>
Guest
Year and Trim: n/a
Re: remote fob
Post by Guest »
Leejr57 wrote:Perfect!! You guys are terrific! My wife is happy,finally,for a few seconds! =D>
you got the key fob to work?
