KR elimination
- 99ssei
- Posts like an L27
Re: KR elimination
Misfires still present. Not as frequent, though acceleration seems a bit smoother with the new wires.
Here's my morning scan. I'm baffled as to why I'm getting misfires. Plugs are new, wires are new, ICM/coils were adjusted. The only thing left is to look at the timing.
http://www.scandepot.net/viewscan.php?pk=5525
http://www.scandepot.net/viewscan.php?pk=5526
- Allmachtige
- Retired Moderator
- Year and Trim: 2009 G8 GT
Re: KR elimination
Not sure if you did this yet, but did you test the primaries and secondaries on all the coils? Just make sure all their resistances are close to each other and within the recommended range. Techinfo has the specifics.
2009 G8 GT - White Hot
415/391
415/391
- 99ssei
- Posts like an L27
Re: KR elimination
So last night I drove into the city to see a concert. I wasn't scanning, however, I had my scan gauge on and noticed I had misfires going on at random times. Nothing was repeatable. Most were at idle, some were right when I began to add throttle. Didn't happen all the time either. Maybe every 2 or 3 minutes. I later noticed that while in traffic, my battery voltage slowly dropped down to 10.9 (normally sits at 13.8-14.0). I had the head lights, fog lights, heater, radio and one sub amp on at the time. I started turning things on and off to see if voltage changed and I only say .1v change. EDIT: Once RPMs were up and I was rolling, the voltage increased back up to 13.8.
Late last night, I was leaving the bar we went to for a night cap and right after I started my car, my DIC said one of my tail lights was out. Not wanting to get pulled over at 1 am, I got out to see and all lights were working. I turned off the car and restarted, then had my passenger go out and check to see if my brake lights all worked. They did and as soon as they got out to check them, the light sensor went off. BIZARRE!
Suggestions?
Suggestions?
Foghorn
- Year and Trim: 1997 SSEi 40th Anniversary
13.07 @ 106.5
Re: KR elimination
Check the ground wire from the battery where it attaches to the engine.
Cheers,
Cheers,
- 99ssei
- Posts like an L27
Re: KR elimination
Checked the ground to the engine. That sucker is in a tight spot right underneath the engine above the sub frame. Very tough to get to. It was covered in soot so I cleaned it up as much as I could. Here's the pic. I put a 13mm wrench on it and tried to tighten, but it was on tight enough (could not turn it). Still random misfires going on. What now brown cow?
- Allmachtige
- Retired Moderator
Re: KR elimination
Something I did for good measure was sanding down the area where the battery bolts to the body, but my battery is in the back seat so that doesn't help much.
Have you cleaned the injectors? I'm hitting a wall with my KR issue as well and I'm toying with the idea that I need to soak my injectors in gas and replace the o-rings.
415/391
415/391
- 99ssei
- Posts like an L27
Re: KR elimination
I replaced the o-rings on the injectors and ran 3M Complete Fuel System cleaner on 1/2 tank of gas back in August.Allmachtige wrote:Something I did for good measure was sanding down the area where the battery bolts to the body, but my battery is in the back seat so that doesn't help much.![]()
- 99ssei
- Posts like an L27
Re: KR elimination
Think I might've found something of interest....
I was comparing (1) my current bin to the (2) Intense bin, to the (3) factory 99 ssei bin, to the (4) 99 GTP bin and found an area that really stood out. The MAF Allowed Delta airflow was significantly different from the GTP to the SSEi. In HPT, "MAF Allowed Delta Airflow: These tables determine the maximum positive and negative airflow (g/sec) change allowed every 12.5ms.
INTENSE & STOCK BIN
GTP STOCK BIN
As a test, I've copied over the GTP figures to my bin and will see if that yields any results.
Does anyone know what happens when the airflow exceeds these figures? Will that retard the timing?
INTENSE & STOCK BIN
GTP STOCK BIN
- 99ssei
- Posts like an L27
Re: KR elimination
Last change yielded no noticeable results.
I was going through older scans and I'm still baffled why I'm commanding 11* and only seeing 7 or 6* with 1*KR yet when I was doing my VE tune, I was seeing 14* with 3-4 KR. (image below is from page 8 of this thread).
At the time, I was commanding 13* of timing in the .92 / 3600 cell.
What happened?
Tue Sep 09, 2008
What happened?
Tue Sep 09, 2008
- agrazela
- Retired Gearhead
- Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired - Location: San Diego, CA
Re: KR elimination
In this other thread:
http://www.pontiacbonnevilleclub.com/fo ... =12&t=6603
You say you swapped in a new high-flow fuel pump recently. Maybe I missed it in the current 17-page thread, but when exactly was this done? Are the scans in the current thread before or after the pump change?
I ask because my recent fuel pump change (to same TRE-340 pump) eliminated all part-throttle (and most WOT) KR on my 1998 LeSabre. Seems my old, worn pump would falter a bit whenever fuel demand spiked, causing momentary leanness and KR.
Bone Stock
Retired
Bone Stock
Retired
- 99ssei
- Posts like an L27
Re: KR elimination
TRE-340 pump was installed 8/22/2008.
HPT arrived 8/26/2008
EDIT: Replacing the FPR today just to eliminate that from the equation.
EDIT2: Bought FPR and tried to put it in, however, the one I got was smaller. I took it back and AutoZone listed that same one for all the models above, below and even for the GTP. I went over to Advance and they too had a smaller one. What's up with that? I"m afraid to order from RockAuto for fear of getting the same *dang* one. Anyone have a similar issue with the FPR?
- Allmachtige
- Retired Moderator
Re: KR elimination
RockAuto has about 3 different FPR listed for my Bonnie. One was a whooping $80! But I assume that's the best one.
415/391
415/391
- 99ssei
- Posts like an L27
Re: KR elimination
Great, I have 4 to choose from! The ones at RockAuto are more expensive than AutoZone and Advance (listed below from lowest to highest price).
Which one is the factory, OEM one? I'm guessing it's the last AC Delco one (also most expensive).
- Allmachtige
- Retired Moderator
Re: KR elimination
That looks like the same parts I come up with. I have no idea why the bottom one is so much more expensive. The description doesn't help either, but personally I'd buy that one because you get what you pay for.99ssei wrote:Great, I have 4 to choose from! The ones at RockAuto are more expensive than AutoZone and Advance (listed below from lowest to highest price).
Oh btw, I only hit 11 degrees of timing in those 0.92 cells (when I have 0KR). Just some reference for you.
415/391
415/391
- 99ssei
- Posts like an L27
Re: KR elimination
What are you commanding (High Oct. Spark Table)? I'm commanding 11 and only getting 6.Allmachtige wrote:Oh btw, I only hit 11 degrees of timing in those 0.92 cells (when I have 0KR). Just some reference for you.
- Allmachtige
- Retired Moderator
Re: KR elimination
Currently using the Intense table:99ssei wrote:What are you commanding (High Oct. Spark Table)? I'm commanding 11 and only getting 6.Allmachtige wrote:Oh btw, I only hit 11 degrees of timing in those 0.92 cells (when I have 0KR). Just some reference for you.
13.01099 - 2800rpm
12.00000 - 3200rpm
12.00000 - 3600rpm
12.00000 - 4000rpm
10.98901 - 4400rpm
10.00000 - 4800rpm
10.00000 - 5200rpm
10.00000 - 5600rpm
10.00000 - 6000rpm
10.00000 - 6400rpm
415/391
415/391
- 99ssei
- Posts like an L27
Re: KR elimination
Called Pontiac dealership and the FPR # for my car is 24506988. They have them for $150, rockauto $72.
1994se
- Year and Trim: 2002 SSEi
Re: KR elimination
$80!? I don't think my AC Delco FPR was that much. It's been awhile though so it's totally possible. I just changed mine for good measure and have a fine stock one here. If either of you want to borrow it to see if that's your problem feel free.
- 99ssei
- Posts like an L27
Re: KR elimination
Too late, already on order from RockAuto. Plus, I'd rather have new parts. Thanks for the offer though! I think my problem might be related to the missing damper issue in my other thread above (really hoping Boostie has a spare rail to send me)
- Allmachtige
- Retired Moderator
Re: KR elimination
Why do you need a spare fuel rail?
415/391
415/391
