Ok, so I just realized a scanning boo boo I made. I was trying to change the PIDs (add/remove) and had some troubles with the histograms not capturing certain data, so I inadvertently used an old config that was not capturing MAF in Hz, commanded AFR nor the TCC Duty %. Gotta go back in and add those.
I'm in the middle of adjusting the MAF +7000 hz. I put the IFR @ 100 kPa back to stock (38.4) and started massaging the MAF. The IFR was 10% lower from stock, so I used the same % to raise the MAF above 7000 starting at 1%, 2, 3, 4, 5, 6, 7, 8, 9 and 10% all the way to the end. In the first scan below is right after the 1st engine cycle - key off, so you can see the trims being learned, but the end of the scan should be good data.
http://www.scandepot.net/viewscan.php?pk=5470
http://www.scandepot.net/viewscan.php?pk=5471
The next scan is a compilation of three scans put together. I think I have a bad cable because randomly, my cable would become "disconnected." I saved the scan, disconnected, re-connected and picked up scanning as soon as I could (while rolling). You'll see this in the frames and time, however, there's maybe a 30 second loss of data between each.
I don't know how to post my bin here, but here's a pic of my timing tables mentioned above. The highest I seen my O2s in all scans were 933.
http://www.scandepot.net/viewscan.php?pk=5473
