Onto the issue(s) at hand...
My Bonne has been acting up lately and is to the point of being nearly undrivable. It has been idling erratically. At first it was idling a little high and then drop back down to appropriate idle speeds with either a motor restart or a quick goosing of the gas while in Park. Recently it was quickly fluctuating between 2000 and 3000 RPMS at highway speed. Last night I was going to head to a buddy's place and it wouldn't idle lower than 3000 RPMS. When I drove 30 MPH it was running at 4000 RPM. I quickly put her back in the garage knowing it needs some TLC ASAP.
I pulled some codes via the paper clip method this morning. It return 21 (TPS circuit - Signal Voltage High) and 22 (TPS circuit - Signal Voltage Low). It also return 36 (Transaxle Shift Control Problem).
I am guessing the TPS needs to be replaced. Anything else I should be looking at to get full diagnosis? Could a cracked vacuum line also be causing havoc?
The TPS was replace about 3-1/2 years ago by a mom and pop garage. How difficult of a DIY is this? I have a Chilton's manual, but I'll be *dang* if I can find the section for the TPS.
Marmot
