KR elimination Volume 2 (2000 SSEi)
Allmachtige
Year and Trim: 2009 G8 GT
Post by Allmachtige »
Subject is a lame joke, but anyway I think we came to the conclusion that a separate thread for my scans would be ideal. I'll still be posting questions/thoughts on 99ssei's thread.
Ok to start off...HP Tuners is an incredibly awesome tool! I've barely scratched the surface and already found more information than I could ever dream of. So lets dig right in shall we?...
Results after a 30 minute drive starting at 7:30pm (10 minute idle before scan started):
CSV and HPL files (these are direct links to my home web server, so if your browser complains of a malicious site please ignore the warnings...trust me, enough people know where I live to come kick my ass if I was some hacker):
http://ente.got-game.org/hptuners/scan_ ... 0pm_01.csv
http://ente.got-game.org/hptuners/scan_ ... 0pm_01.hpl
After a lengthy phone conversation with PDXGTP we came up with some initial settings to try out one piece at a time. Here is what we (he) came up with:
Disable the EGR
Disable CAT over temp protection
The figures you see set to 36 were set to 136 by Intense, which seemed strange
Misc timing "nullifying"
These aren't changes I'm going to rush into by any means. Tomorrow's morning drive to work (45min) will involve another scan, which I'll get posted around lunch time.
In the meantime I'm all eyes and ears for suggestions.
2009 G8 GT - White Hot
415/391
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Re: KR elimination Volume 2 (2000 SSEi)
Post by 2003 SSEi »
you need to MAF tune BAD, 11 LTFT is horrible and im not suprized your seeing KR. you want the LTFT's to lock in at 0.0 in PE or WOT.
you are leanish in your WOT numbers. you need to be in the 910-930, but with out a wideband its almost impossible to tell.
the KR decay is lessened because it will fight off the KR quicker, i have mine decreased as well
your Timing is really low as a result of the KR.
Personally i wouldnt disable the EGR untill i was Intercooled. The EGR actually cools the Intake charge.
Allmachtige
1993 sle wrote: Personally i wouldnt disable the EGR untill i was Intercooled. The EGR actually cools the Intake charge.
Yes, but its unmetered air and could give me some results if I test without it for a day or two.
Also unfortunately I didn't opt for the Pro version of the tuner due to a tight budget (which can scan wideband).
415/391
99ssei
Post by 99ssei »
Looks like we have very similar problems....for those wanting to follow my thread:
http://www.pontiacbonnevilleclub.com/fo ... &start=200
Why did you disable the EGR and CAT over temp protection?
Just checked my KR Decay vs. RPM (high load) and my numbers are exactly like the graph you posted (my PCM also from Intense). Maybe it was missed in the flash?
My boost controls all look the same as the tables you posted except for boost timer adder TCS off:
superchargedSSEi
Year and Trim: 1996 SSEi
Post by superchargedSSEi »
I'm surprised at how much boost both you and Ken are making on 3.5 pulleys. At times you guys are only a couple of psi below what I see with my 2.8 (you actually had one line in that scan at 178kPa, I usually see 180kPa on mine)...just shows how much a cam and intercooler affects things.
Aaron
1996 SSEi (year confused and on the road again at last) : swapped 4T65, cammed and intercooled among other things
Best ET: 13.208
Best trap: 104.96mph
Allmachtige
Ok round 2.
The following is a scan on my way to work under normal driving conditions. Its a 30ish mile drive with country road, highway, and city driving. I started at 7:22am, 69F, and heavy humidity.
CSV and HPL files:
http://ente.got-game.org/hptuners/scan_ ... 2am_02.csv
http://ente.got-game.org/hptuners/scan_ ... 2am_02.hpl
If you look up at my KR, that was just from using the onramp to get on the freeway.
I'd like to try a PE mode drive on my way home tonight. What steps does it require again? I believe just setting the PE to 100 on all values and unplugging the MAF. Anything else?
415/391
99ssei
Post by 99ssei »
Allmachtige wrote:I'd like to try a PE mode drive on my way home tonight. What steps does it require again? I believe just setting the PE to 100 on all values and unplugging the MAF. Anything else?
Nope, that's it. Unplug MAF and set PE to 100.
EDIT: Oh, and reset fuel trim.
superchargedSSEi
Copy your low octane spark table into the high octane one, and don't go WOT while running speed density. Anytime you start seeing the KR ramp up back off, at 14.7:1 AFR you don't have the fuel there to save you. Also, expect the car to run like *shoot* until you tweak the VE table a couple of times.
Aaron
Best ET: 13.208
99ssei
Post by 99ssei »
superchargedSSEi wrote:Copy your low octane spark table into the high octane one, and don't go WOT while running speed density. Anytime you start seeing the KR ramp up back off, at 14.7:1 AFR you don't have the fuel there to save you. Also, expect the car to run like *shoot* until you tweak the VE table a couple of times.
(x 2) When you start the car for the first time, the RPMs will go up and and down dramatically until it levels off at an idle speed it likes. Just warning you now, you may stall once or twice. Don't worry, it's the computer trying to figure out how to calculate A/F without the MAF sensor. Once the RPMs stabilize, start your scan.
Foghorn
Year and Trim: 1997 SSEi 40th Anniversary
13.07 @ 106.5
Post by Foghorn »
superchargedSSEi wrote:Copy your low octane spark table into the high octane one.
I think that's backwards.
Cheers,
99ssei
Post by 99ssei »
Cheers,
Yes, you should copy your high octane to your low. Good catch!
Allmachtige
Please verify the calibration paths so I don't mess anything up.
I believe I found the High and Low Octane tables: Engine > Spark Control > Spark Advance > Under 'Main Spark Advance'.
I thought I found where I change the PE values but lost it. :???:
Also where do I reset the fuel trims? Do I do this after I "Write Calibration"?
Thanks guys.
415/391
Allmachtige
Oh also, this might help...I took some screens of when I hit peak KR this morning:
415/391
99ssei
Post by 99ssei »
Allmachtige wrote:Please verify the calibration paths so I don't mess anything up.
Thanks guys.
http://www.hollandms.com/newbie/tuning_new.htm
Dirthead Racing
Year and Trim: 97 ssei
12.67@103
Post by Dirthead Racing »
Please read this entire thing in detail before you start changing anything. I ended up reading it 2 times then again after I had been working with the tuner for a while. You've got the right people subscribed to the thread but you have some homework to do first :)
http://wiki.opentuner3800.com/index.php?title=Main_Page
Edit: for those that don't know, the link is to Jerry's tuner notebook WIKIFIED
Allmachtige
I have read in multiple times over and I have a habit of asking questions even if I know answers. Working in IT makes me want everything in writing. :wink:
EDIT: So I get everything ready. From what I read I write the calibration during KEY ON, but do I reset the fuel trims during KEY ON or when the engine is actually running? I'm going to assume KEY ON.
415/391
superchargedSSEi
Cheers,
Good catch! Note to self...posting while multitasking is a bad idea. #-o
Aaron
Best ET: 13.208
2003 SSEi
LOTS of Mods
Post by 2003 SSEi »
you can reset fuel trims anytime you feel like. Key Must be on tho
Allmachtige
Gah I made my first MAF adjustment and now KR is through the roof. I'm talking up to 8!!!!!
Results from drive to work this morning:
Changes I made:
CAT Protection raised from 158 to 258:
General increase in MAF curve:
Spark limiter increased from 6200 to 7000:
Files:
http://ente.got-game.org/hptuners/SDsca ... FON_04.csv
http://ente.got-game.org/hptuners/SDsca ... FON_04.hpl
My high octane table is still copied over my low octane table...should I be restoring the low octane table back to what it originally was for MAF table changes? *fook*, its like I'm going backwards now. :evil:
415/391
99ssei
Post by 99ssei »
I left my High/Low octane tables the same after the change. Did you do your VE tables first? I didn't see any postings regarding them. Your LTFTs should be +/-5 on the VE table and +/-3 on the MAF calibration.
