I replaced the VSS in my 1995 L27/4T60-E Silhouette because the speedo was bouncing around and I didn't have third or fourth gears. It worked fine when I test drove it that night. I don't drive the van very much, it's basically used for taking my wife to the dr. because the Cutlass won't hold a wheelchair. Now I only have first, the speedo will move to about 20 MPH then die leaving me in first gear.
Is my trans screwed or is there something I am overlooking?
Another thing is that it takes a couple of seconds to go in to gear when I drive it after it's sat for a week.
1995 Silhouette trans problems
L67Silhouette
- Year and Trim: 1995 Silhouette Series II
L67Silhouette
Re: 1995 Silhouette trans problems
Thats a little confusing to me...
Usually if it was imp home it would be second or 3rd gear... I am not sure what to tell you...
I will assume the Manual functions work? Reverse, Manual 1.... If you were to shift from manual 1 to manual 2 will it shift? And then to 3rd does it shift?
On the my van I had manual 1, but it would not shift on its own... I had to shift it... If it was really cold out it would shift for a few minutes till the trans temps came up a hair and then it was done shifting...
Not sure what to think at this point..
