Module Issues??
Teddybfelts
Year and Trim: 2002 se
Module Issues??
Post by Teddybfelts »
Problem on 2002 se
Driver window problems going up and down (jerking)
Interior lights stay on
dash lights dim on their own
passenger window will only work sporadically
locks don't work
"bright light indicator staying on"
Is this a problem with the interior module? any help would be great.
Thanks
96 SSEi
Re: Module Issues??
Post by 96 SSEi »
be sure the little knob on left side of dash by fog lamps is not turned all the way clockwise - that turns on the interior lights.
bright light, you mean high beam - if you push the turn indicator stick forward, it will stay there and high beams stay on - check that
give the window a couple of light hits with your palm, does it move smoother for a bit?
https://my.gm.com/content/dam/gmownerce ... owners.pdf
see if there is a fuse for locks..........
can you move the mirrors with switch on pass door?
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
Teddybfelts
Re: Module Issues??
The dash light dim and brighten on their own. The "bright light" indicator stays on when I dim the headlights (sometimes). "door ajar" indicator comes on when all doors are shut.
I just think its some type of module going bad or a "junction box".
Sirius
Year and Trim: 2003 SSEi
Re: Module Issues??
Post by Sirius »
The first thing I would do is check and clean all the electrical ground points. It's cheap and easy - well, cheap anyway. Poor electrical returns can exhibit some wacky symptoms. Do a site search, I think there's probably a post that points out the major chassis grounds.
Resident Tightwad
Screw you, Photobucket.
Teddybfelts
Re: Module Issues??
I'm having the exact same issues. Has there ever been a solution discovered?
Re: Module Issues??
I'm confused. You are the original author from 2 years ago, but you never updated anything. Did the problems go away for a period of time?
Teddybfelts
Re: Module Issues??
those problems are still there. After doing alot of researching, I think of got a couple of things going on. On the windows, I think I need the driver door window "modulator". I'm not sure about the other stuff.
skinny
Year and Trim: 2000 SE
Re: Module Issues??
Post by skinny »
Hazzard warning/turn signal flasher not working. Where can I find a replacement
Re: Module Issues??
skinny wrote:Hazzard warning/turn signal flasher not working. Where can I find a replacement
I have them available. PM or email andrew.suderman@gmail.com
