Two out of the three tensioner/idler pulley bearings were intermittently making noise and the belts were due for replacing. I decided to replace all three pulleys, the belts and while I was at it, the leaky crank seal I mentioned a few posts back.
For holding the crank I tired to get the BMW damper holder tool but the lead time was too long. I saw what others have done and picked up from 2" flat stock to make a holder with just incase I couldn't make any of the existing tools I have work. It turns out I was able to make the water pump holder tool I had from my 528i work. The only issue was one of the four E14 bolts was blocked and I just had to reposition the tool for the last bolt. The holder doesn't actually fit the my water pump bolt pattern but I'm able to still use it without damaging anything.
Removing the crank seal was very easy with a Lisle limited access seal puller (p/n 56920). I don't know how I got along without this before.
For a seal driver I read of some using sockets and also 2" PVC pipe. If there was more room I would just use mallet and driver. I liked the idea of threading it down evenly in this case. I picked up a PVC 2" pipe cap and a 2 to 1.5" reducer. I traced the 4 bolt holes of damper onto the 2" cap, drilled them out and used the cap along with the original bolts to pull the new crank seal evenly into it's bore. The cap had a small lip (pictured below) that actually held the seal nicely but the same lip stopped the seal from being pressed in completely flush. The 2-1.5" reducer didn't have a ridge and would seat the seal flush but was too tall to start with. It's a shame because the factory thrust washer the damper bolts tighten down on actually seats perfectly inside the reducer. With the seal almost all the way in, the bolts are long enough to thread this combo down and get the seal flush. Longer bolts and/or a way to cut either PCV part down true would mean you only need to use one of the PCV parts. I didn't have either but this worked just the same.
You can see some water pump seepage at the mounting face in a few of the pics. I'm going to let that live for now. I also decided not to replace the hydraulic tensioners since they seem to still be in working order.
Getting the seal area clean
New seal with silicone grease
2" PCV Cap
2-1.5" reducer + factory thrust washer
Water pump holder tool in action
Yep, it was time
2" cap with lip on the left, 2-1.5" reducer with no lip on the right
Info on dropping a 92-99:
Here.
