Harmonic blanacer replacement
- Pair of SSEI
- SSEi Member
- Year and Trim: 1997 SSEI 40th
Well, I have the sound of a bad harmonic balancer. My question. Is this repair done through the right front tire area? Do I have to remove the motor mount. I have done this repair on a 3800 in a GP. But this is the firsrt time on the bonnie. While apart what else should I look at replacing?
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, 3.5 mod. Pulley, SD Headers, Intense Stage 1 tune, MagnaFlow Cat 94109, Catco catback, Autolite 103s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
Re: Harmonic blanacer replacement
Yeah, through the wheel well. You might want to change the belts while you're at it, but unless you're having other issues, high enough mileage to justify changing the timing chain, not much else to really do since you won't be going that far into taking things apart. You shouldn't need to remove the motor mount, only the bottom bolt and spacer to get the belts off if you want to change them.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- RJolly87
As Matt said, belts could make sense if they are needed, but that's usually a stand alone repair right there.
Make sure you have the proper bolts for your pulley puller however. From what I understand, the 3800's have a thread pitch that is not typically included in a lot of universal kits, and the balancer bolt requires a significant amount of torque to remove, so be sure to have a good impact close by to make life easier.
~Randall~
- J Wikoff
- Year and Trim: 1992 SSE
They are M6x1 if I remember right. Most kits have 1/4-28 bolts, which is close, but you risk screwing up the threads beyond usability.
- Pair of SSEI
- SSEi Member
Thanks guys.
Paintjar
- Year and Trim: 1995 Bonneville SE
Hi, I was reading your post trying to figure out where a knocking rattling sound is coming from on my 95 3800 Bonn. It doesn't change when I vary RPMs. What does the sound make coming from the balancer? Sometimes it effects the starting. Thanks for any advice on where to look for a problem.
- J Wikoff
Yours might be a flywheel or starter issue. I'd start a new thread.
