03 Bonneville SE water in back pass floor only
jsnyder49090
Year and Trim: 02 SE and 05 GXP
Post by jsnyder49090 »
I hope this is in the right place been having issues on this site when using on phone.Water in pass back floor i have read the threads no sunroof the door seals are fine i need to figure it out.I want to paint the car but cant until this issue is resolved i took some pics of seals etc . I was going to post pics but i dont know how apparently
Re: 03 Bonneville SE water in back pass floor only
Make sure your front and rear door seals are good.
I have no sunroof and I kept getting water in the back. It was actually the front door that was leaking and got water in.
jsnyder49090
I know the door seals are good I have pics I have no idea where its coming from. I have read a lot of these old threads I will read again I tried to post pics but it didn't work out so good.I want to get the car painted but am not going too until I fix the water leak If i could post the pics it would help the seals are all fine
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
The doors seal at 2 points; inside the door itself with plastic sheeting and again at the rubber seals which surround the door.
When the water seeps inside, it often runs down a weld (behind the plastic trim) and under the carpet.
There is also the possibility of leaking welds, especially the "gutter" that runs above the doors.
Next up is a rear windshield leak.
It sometimes takes a bit of detective work to figure out the source of leaks.
Huge number of threads about the door leaks, this one with pics: http://www.pontiacbonnevilleclub.com/fo ... 43&t=11470
