04 SLE P0420 code day after passes inspection
Jdub34
Year and Trim: 2004 SLE
Post by Jdub34 »
Hey everyone. Like the title says I got that code immediately after passing emissions and inspection. What are the odds of that? Exhaust has been louder than usual lately though but no obvious performance loss. Is it possible the shop bumped something loose that I could check or is it just coincidental timing and my cat is bad.
luke_dubs
Year and Trim: 2013 Regal GS
Re: 04 SLE P0420 code day after passes inspection
Post by luke_dubs »
EVAP system could actually have a problem, or the oxygen sensors on either side of the cat are bad. I highly doubt that the cat is bad.
'02 Pontiac Bonneville SE 108,539 miles, N/A, SSEi exhaust system, boat roller mount. Gone, but not forgotten.
'13 Buick Regal GS 122k miles, 270 hp, 295 lb/ft, ZZP intake.
(yes, there is a story behind my avatar.)
At least it happened right after the inspection. Haha
luke_dubs wrote:EVAP system could actually have a problem, or the oxygen sensors on either side of the cat are bad. I highly doubt that the cat is bad.
#-o Ummm, no. The P0420 is almost always a bad cat.
Jdub34
Post by Jdub34 »
Thanks guys. The exhaust is really rattling in the area of the cat so I'm thinking the crap came loose inside. Just crazy how it threw the code day after inspection.
96 SSEi
Post by 96 SSEi »
the pcm gets cat info directly from the O2 sensor near the cat - get that checked out first.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
nos4blood70 wrote:At least it happened right after the inspection. Haha
:beerchug: Gives you a bit more time to address the issue.
