Still working out details for the faceplate. I ordered a small true sine wave power inverter for the player and screen. Planning to hard-wire it in and mount the power switch on the faceplate. The unit should be small enough to fit right behind the bluray player, but I want to make sure certain ports are accessible. I also want to find a panel-mount fuse holder for it, as well as a couple of USB ports. I have a dedicated power distribution block that I plan to use to re-wire anything and everything audio to a single point. Hopefully this prevents any issues with ground loops. I'm using a few clip-on ferrite chokes that will hopefully prevent any other noise issues.
The inverter is rated for 300W continuous and a 700W surge peak. Since the player and screen combined pull only 125w there's some room for something else small like the tablet charger or anything else I might want to use to pass audio to the system. For the USB ports I'm looking into something that is a modern (3 amp) version of the good old 7805 voltage regulator. The 7805 circuit inside my SSEi stereo was the key to eliminating noise on the line in for that radio, but I want fast charging as well. Then the bluetooth adapter I got is also USB powered, so there's a lot of stuff that needs to be on the dedicated power block, so hopefully I have enough spare computer parts and things like that on hand that I can keep things rolling despite the cold snap and snow we've had for the last 3 days.
