Erratic Gas Gauge
deano55
- Posts like an L36
Erratic Gas Gauge
Hi folks, my wifes 02 Regal gas gauge was dropping off and rising slowly so I thought bad sending unit so, I change the whole unit, pump and sending unit. It wasn't the problem, now the gauge is going completely full and dropping to empty and not slowly. Today I went under neath to check the connections where they go through the trunk and also played with the connections at the top of the tank, nothing!! The wire harness goes down behind the passengers side of the back seat then, along the passenger side rail in the floorboard. Without taking the jam molding and the seat out I couldn't feel or see it any further. Is there a problem area with these or might it be the BCM?
- RJolly87
Re: Erratic Gas Gauge
I would check to verify if the gauge is doing what it's told, or if it has a mind of its own.
2000+ year model GMs have a reputation for failed stepper motors in the gauge clusters.
~Randall~
deano55
- Posts like an L36
yes, a instrument cluster repair guy said the same only, they don't repair them. Are they repairable or maybe just this guy?RJolly87 wrote:I would check to verify if the gauge is doing what it's told, or if it has a mind of its own.
dougtoth
2005SLE PEARL
Contact Andrew at Bonnevilles Unlimited.
He repaired my Cluster.
www.bonnevillesunlimited.com
Phone (507) 220-2000
He does excellent work.
I am sure he can help you.
deano55
- Posts like an L36
ok, thanks
deano55
- Posts like an L36
never did ask how do you check if the gauge is doing what it is told?RJolly87 wrote:I would check to verify if the gauge is doing what it's told, or if it has a mind of its own.
deano55
- Posts like an L36
the sending units little float pickups were bad from the get go on the new pump, 150.00 dollar unit and thats what I got
96 SSEi
- Posts like a Northstar
OPEN THE HATCH IN THE TRUNK TO access the pump - move the float arm up and down while you or helper observe the gauge
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
