ABS control module question
wpbrink
Year and Trim: 1998 pontiac bonneville se
Post by wpbrink »
99 Pontiac Bonneville se .... has anyone ever re-soldered their own ABS control module? If so how exactly did you do it? I see YouTube videos on doing it yourself. Finally what is the make and model for my particular ABS module?
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re: ABS control module question
Post by MKMike »
As tempting as it is, I haven't done so myself.
Opted for a used module off Ebay, since Andrew (Harofreak00) didn't have the one needed for my 2001.
As for module numbers, it depends on the options that your vehicle has. I think there are only 2 types but am not 100% sure--with or without traction control.
Best bet is to get a close look and either copy all the numbers from the EBCM label or just snap a pic.
If your Bonnie doesn't have traction control, the Rockauto does not have a remanufactured unit for you.
Search past threads and you might find repair experiences.
95naSTA
Post by 95naSTA »
Just out of curiosity, is this just fixing broken wiring or something else?
MKMike
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
Typically, the issue is internal; one or more bad solder joints.
