blend door?
jcweis1
Year and Trim: 2000 & 2005
blend door?
Post by jcweis1 »
Sorry... tried to find a post but no luck on this one.
2000 Bonneville with manual AC /Heat controls. Cold air only blowing out of front dash panel on the two right side vents. The two drivers side vents do not blow cold.
I believe it is a blend door but which one is it and how do I locate it? Will this be a hard fix?
Thanks for any help I can get with what the problem is and how to fix.
Jeff
jcweis1
Re: blend door?
Post by jcweis1 »
Sorry thought should clarify a little more.
The drivers side left two vents blow air but just not cold air like the right two do.
thanks again
96 SSEi
Re: blend door?
Post by 96 SSEi »
pass side colder than drivers may be a sign of low system charge - check that first.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
luke_dubs
Year and Trim: 2013 Regal GS
Re: blend door?
Post by luke_dubs »
It would be a blend door problem if all the vents blew only cold air.
'02 Pontiac Bonneville SE 108,539 miles, N/A, SSEi exhaust system, boat roller mount. Gone, but not forgotten.
'13 Buick Regal GS 122k miles, 270 hp, 295 lb/ft, ZZP intake.
(yes, there is a story behind my avatar.)
jcweis1
Re: blend door?
Post by jcweis1 »
I did just add a can of refrigerant, old cheapo gauge read in the green zone afterwards.
96 SSEi
Re: blend door?
Post by 96 SSEi »
accuracy is questionable so go by weight - 1 can should be equal to 1 pound and we need 2-2.5 lbs so maybe add another can and watch the pressure.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
