Driver information center doesn't work properly
cinzy0
Year and Trim: 1992 SSEi
Post by cinzy0 »
Hi@everyone
I got a problem with my DIC, just like this http://www.pontiacbonnevilleclub.com/fo ... 34330.html
50/50:Sometimes it works fine. OR during systems check it flashes and then turns off and again 50/50 DIC starts to work after 5-10 mins
Compass and everything else in the cluster always work fine
I didn't check fuses because it's night already
Any suggestions?
96 SSEi
Re: Driver information center doesn't work properly
Post by 96 SSEi »
you may want to remove the dic and check the connection in rear
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
jonnevilleSSEi
Year and Trim: '97 SSEi
Post by jonnevilleSSEi »
I had the same issues in my 97. Was never able to fully resolve it after 5 times removing the dashboard and instrument cluster to clean and manage the pins. If you're ready to try that I have the process documented somewhere on this forum, in detail with photos and things I had to learn the hard way. Let me know if you have any trouble locating my post about that.
What it seems to come down to is both clusters (Compass and DIC) are connected to the computers with a separate bulk wire connector (20+ pins?) I saw mine had a bent pin, not sure from what, nor if that had anything to do with the problems. I noticed when it would flicker off that I could press on the plastic cover (fully assembled) and pressing it towards the front of car (into the dashboard) would illuminate it temporarily, though sometimes it would stay on. I'll look for the article, I hope you are able to fix yours, it used to bug the piss out of me, every time I thought it seemed resolved.... and my heart would feel failure when it shut off again.
http://www.pontiacbonnevilleclub.com/fo ... 46475.html
'97 SSEi, Majestic Teal / Beige interior, Bose, HUD, iPod ready! - SOLD! :sad: Check it out!
'99 Buick Regal LSE, Matador Red / Beige interior - SOLD! Check it out!
'96 Chevy Camaro - White w/Black / fire red interior, 3800, manual, loaded, T-tops, Bose - SOLD! Check it out!
cinzy0
Post by cinzy0 »
Thx a lot
I'll try to look and fix this
cinzy0
Post by cinzy0 »
I don't want to make another thread
I always got SES light while using brakes or going downhill
And which scanner better to buy for 92 bonne?
cinzy0
Post by cinzy0 »
Problem solved, thx a lot :) Bad connection.
I hope this doesn't happen again :>
96 SSEi
Post by 96 SSEi »
92 WOULD NEED AN obd1 scanner - get a basic one that will pull some real-time data also - the good ones get very pricey
$100 - 200 should get you one that will help you be happy.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
