Hey all,
I've been lurking in this forum for awhile now and today is the day I need some assistance. I tried to see if anyone else had this issue but I couldn't seem to find anything; that or I was just doing it wrong. So to start off I have a 2005 Pontiac Bonneville GXP and have had the car for roughly 2 years or so. It was originally my Dad's car and he had it for 9 years and loved it, but when he wanted to upgrade he passed the car down to me. I have loved the car forever and we have had our fair share of problems ie water pump going bad, upper radiator coolant hose exploding, vacuum hoses tearing apart and a couple other instances but nothing too major. The car has 159k on it currently and she keeps pushing on which is awesome. So back to why I am here. My current issue is that my rear calipers are not sitting correctly on the rotors which is causing a lot of travel in my brake pedal before it starts slowing down. I have been looking for a replacement set and it has been a bit more difficult than I thought it would be. I figured I should just replace all 4 calipers just because and my dad and I love doing projects together and its just more preventative maintenance I suppose. I would like the calipers to match the current red ones so I was either going to buy ones and spray paint them or try and find ones that already come painted. I have been looking at rock auto and there are some decent ones on there, but today I cam across a set of 4 on ebay that already come painted red and are pretty cheap, but in the "Fits this Following Year and Model" section it says that it only fits 2005 SLE and SSEi models. So here is my question, does the GXP share calipers with those models or are they different? As far as I can tell they look the same, but I would like to get a second opinion. I can send the link for them if I am allowed to. Also sorry for the long post, I wanted to intro myself just so I don't seem like a complete stranger.
Front and Rear Calipers
- Luxrain
- Posts like an LG3
- Year and Trim: Black 2003 Bonneville SLE
Re: Front and Rear Calipers
well considering 2003 was the last year for the ssei i would probably say those might not be GXP brakes. i wouldnt be sure and maybe someone else might post different but maybe a link to them would help distinguish them
- nos4blood70
GXP front caliper are unique to the GXP. The rears are identical to the SLE/SSEi but they have a different but larger bracket that allows for the use of a larger rotor.
Sullivan
- LE Member
- Year and Trim: 2005 Pontiac Bonneville GXP
Here is the link:
ebay.com/itm/291998498436?_mwBanner=1#vi-ilComp
MKMike
- Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Assuming the inner and outer brake pads are wearing evenly, I highly doubt that the calipers are the cause.
Much more likely would be lateral runout of the rotors.
What happens is the rotor keeps hitting against the pads, pushing the piston back in.
See this:
http://www.autozone.com/repairinfo/comm ... l%20runout
See this:
- CMNTMXR57
Rears are the same as Carl posted.
I am confused by the comment about the rear caliper not "sitting" properly. There are only two bolts (caliper pins) that secure it to the caliper bracket, so it fits over the rotor only one way. If you're referring to the "swept" area of the rotor, the pads will not sweep 100% of the available surface. Especially close to the rotor hat (the center section), as well as the outer edge.
If you're having long pedal travel, a couple things come to mind, going from simplest to most involved;
1) is the system properly bled? If their is air in the system, it will compress, giving the illusion of extra pedal travel before actual braking work is performed.
2) Is the rotor you have, the proper thickness?
3) Your caliper isn't "floating" properly. As mentioned, there are two caliper pin bolts (1 top, 1 bottom), that secure the caliper to the caliper bracket. The design of these pin bolts allows the caliper to slide, or "float" as the brakes are engaged/disengaged. When you press the brakes, the piston on the inboard side pushes out, which then causes the caliper and the outer pad to slide in, effectively clamping the rotor on both sides.
If these pins aren't propertly lubed/greased/etc, the caliper "freezes" and won't float freely, which can lead to quicker and excessive pad wear (particularly the inboard pad), which will then also give the sensation of extra effort needed to get the brakes to work as they've wore AND the caliper isn't "floating".
Typically, getting these pins out, cleaned of old grease and other crud on the sliding section of those pin bolts, and then regreasing, and upon reassembly, ensuring that the caliper can move freely in and out, you may not need to buy new calipers.
Daily Drivers:
2011 Camaro SS
- nos4blood70
I rebooted and regreased my calipers and it has given them some new life. All you need to accomplish this is some grease and brake parts cleaner. It is a quick and easy way to save some money if it ends up being your fix. Plus it takes very little time.CMNTMXR57 wrote:
Sullivan
- LE Member
I never really thought about the slide pins. I replaced the rotors and pads little bit ago and I know I re-greased the slide pins front and rear but it wouldn't hurt to bleed the system and re grease the pins before I bought new calipers. I'll do that this weekend and I'll get back to you guys on it. Thanks so much for all of the help.
