Replacing headlight switch
John Deere Boy
Year and Trim: 1993 SSE
Member since Nov 2003
Post by John Deere Boy »
How much of the dash has to come apart? Just spent a day fiberglassing cracks and broken tabs in my door panel and don't want to dig into the dash if it will be another storm of old fragile plastic tabs. Only looking to fix the dead spots in the dash dimmer so should i leave it be?
J Wikoff
Year and Trim: 1992 SSE
Re: Replacing headlight switch
Post by J Wikoff »
Take the dash panel off, then the panel above the gauge cluster, IIRC. I did mine a couple years ago and didn't break anything. I don't remember taking too much caution either.
skregal
Year and Trim: 95 SSEi
05 GXP
Post by skregal »
i've replaced mine like 4 times now. I can do it blindfolded.
Main clipped-on front panel has to be popped off. Bezel around
the switch and top panel over the cluster. I believe they
are torx screws. It takes alot of wiggling to get the switch
out of the hole but it will eventually come out.
The only real risk is popping the clips on the front panel, which
could break.
John Deere Boy
skregal wrote: The only real risk is popping the clips on the front panel, which
could break.
When you say front panel, are you talking about the fascia that covers the vents, HVAC, radio, and gain slider? If so i'm good there.
Thanks! My interior plastics have turned into a house of cards. Maybe from too much armorall.
John Deere Boy
I waited to long to do this. The switch for auto headlamps is no longer available. Can the switch for manual headlights be piggybacked on to the back of my automatic part of the switch?
J Wikoff
Post by J Wikoff »
I wondered that same thing when I was doing it. I don't remember the conclusion I came to.
John Deere Boy
Ordered one, i'll report back.
John Deere Boy
Yep the Standard Motor Products DS656 switch screws right on the back of the twilight sentinel part. No need to find the discontinued DS657. Check out the filings and/or corrosion on my old dimmer.
I wanted to remove the cluster and clean the connections for my intermittent DIC, but couldn't get enough wire pulled out to disconnect the cluster. The plastic is all so fragile.
J Wikoff
Post by J Wikoff »
Excellent. Good find!
SSEBonne4evr
Year and Trim: 99 Bonneville
Post by SSEBonne4evr »
kool nice job
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
Thanks for posting your result.
Surely it will help others.
I appreciate the good clear pics, too.
