New owner... From the UK
New to the forum? Introduce yourself here. Been around awhile? Tell us about yourself.
JimmyF
Year and Trim: 1979 Bonneville Brougham coupe
Post by JimmyF »
Hi, not sure how many Brits are on here, but just bough myself a 1979 Bonneville Brougham Coupe in Matt black.
She's a beaut and an awesome car, but needs a little bit of attention so I'll be asking a fair amount of advice. Probably a lot of stupid questions aswell... Haha. This is my third American vehicle and she's my daily drive. I need to source a drivers door. Immediate issues to resolve are wiring in a retro sound model 2 headunit and fixing the fans/air con
Image[/[URL=http://s1190.photobucket.com/user/jamesferris1983/media/C42CA921-B1D6-4464-83C2-B9C68A79C7E1_zpsfeeq1vty.jpg.html]Image[/[URL=http://s1190.photobucket.com/user/jamesferris1983/media/EA687D2F-FCC5-4C68-9C29-7DD3C0AA0B89_zpsym8fmjrc.jpeg.html]Image
96 SSEi
Re: New owner... From the UK
Post by 96 SSEi »
hi, welcome!! Must be a tight squeeze getting that bad girl through the city
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
JimmyF
Post by JimmyF »
You're not wrong. I've already scared the hell out of a few people. Although, to be honest, most buildings will give way before that car does :)
Yagyu
Year and Trim: 1997 SSEi
Post by Yagyu »
Pretty cool to see a Bonne owner from across the pond, and a fairly classic one at that.
1997 Bonneville SSEi
-3.4" supercharger pulley
-ZZP Powerlog
-Flowmaster 80 Series exhaust
-160 degree Tstat
-Overkill ASI short ram intake w/ Spectre filter
-Overkill tuned PCM
-Drilled and slotted rotors
-NGK spark plugs (2 heat ranges colder)
-Optima Yellow Top battery
redfury
Post by redfury »
p-l-u-s-h...who cares with that interior, you'll be the most comfortable Brit waiting to get around. What's wrong with the drivers side door? The pics don't serve up much for clues with the black paint...
rustyroger
Year and Trim: 1998 Buick Park Avenue
Post by rustyroger »
Hi Jimmy from a fellow Brit. Whereabouts are you?. Nice car btw, do you get to many shows?.
What issues do you have with wiring and the heating/AC?. We'll help you if we can.
Roger.
JimmyF
Post by JimmyF »
I may have smashed the drivers window after trying to fix it falling off the rails... Oops. Haha.
I'm Chelmsford, Essex and haven't had the car long so not go to many shows. Got a couple lined up, although the thermostat is sticking so waiting on a replacement to turn up.
As for the heating, nothing happens at all, literally nothing.
Welcome to the club! Looks like quite the car.
rustyroger
JimmyF wrote:As for the heating, nothing happens at all, literally nothing.
No fan?, no heat?, no cold air?, all of the above?.
That's three separate faults. No heat might be because the heater matrix was leaking and a po has bypassed it. No fan could be simply a fuse, or a bad fan, the fan should always be on with the engine running, the car was built that way. No cold air probably means the system has no gas in it.
A thermostat should be easy to get, Customville in Dagenham are normally good for parts, or US Automotive near Bedford.
If the door glass isn't shattered Rock Auto should have what you need, they sent the parts for an Oldsmobile with a similar problem quickly and at a fair price.
Roger.
JimmyF
Post by JimmyF »
Brilliant, I knew there was one in Dagenham but couldn't remember it for the life of me!
