Water in the left rear floorboard
fmacnak
- Year and Trim: '95 SSEi
Hi all, so after it rains I get a wet carpet on the left rear side of the vehicle. Any thoughts on how that occurs? I don't think my door seals are leaking. I'm wondering if it's the sunroof drain is plugged or loose. Any thoughts?
95 SSEI (modified-cammed, ported & portmatched, custom Positraction trans)
99 C5 (too original-can't bear to make it a project)
09 Escalade (to tow my projects around)
03 Bmw 330 Cic (the foreigner)
Re: Water in the left rear floorboard
96 SE, same symptom, checked door seals, etc. (this car not equipped with sunroof). solution, caulked around fresh air intake (located between wipers). also should clean any trash in wiper well.
- J Wikoff
- Year and Trim: 1992 SSE
It could be the sunroof drain. Pop the rear seat bottom out and see if it's wet under that side and look for evidence of water trails leading up near the door.
- Pontiac1
- GXP Member
- Year and Trim: 1993 SSEi
If it is the sunroof drain,use some good glue to adhere it when you put it back on or it will come off again in the future,happened to me.
SSEBonne4evr
- Year and Trim: 99 Bonneville
Wiper intake as stated was my left leak.
Also, Re install the door seals filling in the bottom
with a piece from the yard.
Could be as much as 2" shorter at the bottom when you do this.
http://www.pontiacbonnevilleclub.com/fo ... 39736.html
- Baconboy95
- Year and Trim: 1993 SE and 1995 SSEi
Be sure to check for shrinking door weatherstripping as well.
MKMike
- Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
I took no chances on mine; RTV and zipties to secure the tubes to each other.Pontiac1 wrote:If it is the sunroof drain,use some good glue to adhere it when you put it back on or it will come off again in the future,happened to me.
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
Hole in the wheel well?
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
96 SSEi
hi, I had this in my 96 SSEi and it was a small oval piece with little tabs in the floor
look under the car and you will see it - caulk it after cleaning and it will stop the water ingress
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
