2000 Bonnie VIN-K AC Colder on right than left
dandyd
Year and Trim: '91 Olds 98 Regency Elite
'88 Bonneville
Post by dandyd »
The air from the vents is about 42-45 degrees on the passenger side, and about 55-58 degrees on the drivers side. I have checked the blend doors and they all work for the entire range of motion. What else can I check?
Re: 2000 Bonnie VIN-K AC Colder on right than left
Check the charge. Cooler air on the passenger side often means low freon.
dandyd
'88 Bonneville
Post by dandyd »
The charge is fine, It's 40-45 on low side, and 200-225 on the high side with ambient temps of about 90 degrees.
RJolly87
1994 Buick Regal Custom
Post by RJolly87 »
I agree, it's likely low on refrigerant. The compressor can adjust its displacement which can cause the pressures to look okay, despite actually being low.
All r134a charts suggest your low side is down by 5 psi, and high 50psi.
I would bet that adding one can of refrigerant makes the problem go away. The only exception would be if you know how much refrigerant is in it exactly, which would only be possible if you did a full evacuation and charge just recently.
~Randall~
dandyd
'88 Bonneville
Post by dandyd »
I did, a full evacuation 2 days ago, replaced the oriface tube and a recharge with 3 12 oz. cans of 134A.
agrazela
Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired
Post by agrazela »
dandyd wrote:I did, a full evacuation 2 days ago, replaced the oriface tube and a recharge with 3 12 oz. cans of 134A.
And...?
Bone Stock
Retired
dandyd
'88 Bonneville
Post by dandyd »
It was blowing very cold after the recharge...then today it stopped blowing cold.... I put the guages on, and I had 30 on the low side and just under 150 on the high side..... I have a leak somewhere....... I ran the lines with my 'sniffer' and only found one area of 'suspicion' but I've known that sniffer to fool me at times..... I put a shot of dye in the system and will check it day after tomorrow to see if I can locate the leak.
Luxrain
Year and Trim: Black 2003 Bonneville SLE
Post by Luxrain »
id check around the condenser in the front of the car since it takes the most beating
dandyd
'88 Bonneville
Post by dandyd »
I will check it tomorrow, after it's had a day and 1/2 to circulate the dye. Always something..... obviously it's a slow leak because it held vaccuum at -30 for nearly an hour before I recharged it.
dandyd
'88 Bonneville
Post by dandyd »
I found the leak! It was leaking very slowly at the O-ring in the line set just before the compressor (The dye I put in confirmed where my Sniffer was hitting on)...... Changed out the O-ring, not leaking now...... Evacuating system and will recharge within the hour.
