No start on a 2000 Impala LS..... has fuel and spark, help?
Talk about the other 3800 powered GM cars, particularly for items not covered in other sections that may be unique to your year/model, and differ from a Bonneville.
dandyd
Year and Trim: '91 Olds 98 Regency Elite
'88 Bonneville
Post by dandyd »
My daughter went to the store this afternoon in her Impala LS (3800) and when she went back our half hour later the car would not start...called me..... I pressed the shader valve on the fuel line and fuel streams out quickly...... then I put my spark tester on the #1 plug and it had spark...... still won't start (it was running just fine 30 minutes earlier)...... I swapped out an ignition module just to "See"......still no luck...... what else...... Answer me this.... IF a Crank Shaft Position Sensor goes bad will it still produce a spark (just at the wrong time)...... I had an issue like this once before....seems it was sparking but would not start? Thanks for any help?
dandyd
'88 Bonneville
Re: No start on a 2000 Impala LS..... has fuel and spark, he
Post by dandyd »
Well, even though I pressed the shader valve and fuel spirted out....... I just went out had my daughter turn the key as I laid in the trunk..... NO sound from the fuel pump......... Hmmm....may be the problem.
96 SSEi
Post by 96 SSEi »
hi, please be sure to check fuses/relay for pump
also, the crank position sensor indirectly has an effect on injector pulse
you can check it here.................http://troubleshootmyvehicle.com/gm/3.8 ... k-sensor-1
I just looked over the page and it says this............
Taking all of the above into account, the most important thing to remember is that if you get spark from any spark plug wire... the crank sensor is working and the test in this article won't help you.
please post back with your progress and good luck!
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
dandyd
'88 Bonneville
Post by dandyd »
Well the problem is fixed...replaced the Fuel Pump and it runs beautifully..... so glad GM started making an access panel in the trunk so the tank doesn't have to be removed..... I did the job in under a 1/2 hour..... AND with a redone hold down ring....... beating the daylights out of the old ring is a thing of the past.
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
dandyd wrote:Well the problem is fixed...replaced the Fuel Pump and it runs beautifully..... so glad GM started making an access panel in the trunk so the tank doesn't have to be removed..... I did the job in under a 1/2 hour..... AND with a redone hold down ring....... beating the daylights out of the old ring is a thing of the past.
Amen to that.
Dropping the tank was the worst part, after 20 years of road salts.
Glad you got it fixed.
Thanks for reporting back on the remedy.
