Subwoofer to monsoon amp
Solid_speed
Year and Trim: 2002 ssei
Post by Solid_speed »
Will the monsoon amp power a a single twelve inch sub? I'm meaning, if I disconnected the 6x9s and ran a wire from one or both to the sub would it provide more base then the 6x9s? It seems as tho the speakers themselves peak way to early and the amp has more to give, so i was just curious.
Re: Subwoofer to monsoon amp
Nope.
You need a line output converter and a separate amp to power subs with the stock system in place.
Solid_speed
How does one use this and thanks for the reply!
