something strange with oil filler cap
96 SSEi
Post by 96 SSEi »
hello, just 3 miniues ago, I went out to my car to smoke- cant smoke in bar
check fluids- all is good: oil colour is a bit dirty but smells fine.I pull the oil filler cap and there is a bit of yellow residue on the cap: pull the other part of filler and all is good. what the hell is that???? I did use risol/bars stop leak to fix a tiny block heater drip: im going to do oil change early- still have 40% to go from my dic
any guesses as to why I have this residue? am I a victim of attempted sabotage?
thanks............
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
J Wikoff
Year and Trim: 1992 SSE
Re: something strange with oil filler cap
Post by J Wikoff »
It's on the inside of the cap? It's water and/or coolant condensate. It could be normal, it could be a sign of coolant leaking into the oil VIA the lower intake manifold gaskets. How much?
96 SSEi
Post by 96 SSEi »
not much: about 2.5mm2 area so about less than 1/2inch and there was what looked like a drop of water in the cap
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
Luxrain
Year and Trim: Black 2003 Bonneville SLE
Post by Luxrain »
mine does something similar but i dont ever have to add coolant and the oil has no water in it, so just keep an eye on oil vs coolant and if neither seem odd you should be ok
Goostoff
Year and Trim: 2000 SE. 2000 SSEi, 2001 SSEi, 2002 SLE
Post by Goostoff »
Just condensation. If you let the car warm up in the winter time you will see this more than you will in the summer.
96 SSEi
Post by 96 SSEi »
ok thanks, is there a test i can perform to check manifold gaskets without a tear-down?
if there is a leak, would it not affect oil colour?
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
96 SSEi
Post by 96 SSEi »
oh man!!! Now i'm paranoid
like it says on my camping beer coolie: only the paranoid survive....lol
its getting dark so tomorrow I pull the front rocker cover for a better look.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
garagerog
Year and Trim: 2004 SLE
Post by garagerog »
Easiest non-invasive way to determine if you have coolant or water in your oil is to do an oil analysis at your next oil change. I've used Blackstone Labs in Indiana but there may be labs in Canada that do this also. For $28 US they will give you a comprehensive analysis and for another $10 you can get a test on the additive package that will help you determine whether to rely on the OLM for oil change intervals. Blackstone supplies the kit for free, you only pay when you mail the sample back in and I usually get results back in about a week, I've been very pleased with their results and service.
96 SSEi
Post by 96 SSEi »
ok, thanks for the info garagerog
I went for a 50 klm drive last night and pressure in the rad hoses is good and level in overflow is steady.
I didn't see any thing bad on the rockers and the yellow stuff is now gone from cap but I'm gonna do oil change despite the good news
thanks for help all.....
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
