Power windows and locks quit also the radio HELP
Reller24
Year and Trim: 2001 Bonneville SSEI
Post by Reller24 »
Just bought the car with these known issues. Would love some help if anyone could provide me with a starting point.
Don't work - power windows, power locks, power mirrors and radio
Thanks
Archon
Re: Power windows and locks quit also the radio HELP
Post by Archon »
What have you checked so far? Fuses? Relays?
Reller24
Post by Reller24 »
All fuses and relays are good.
Archon
Post by Archon »
More details of the exact symptoms, and what you have done so far would help a lot.
Do the windows not work from any position? Do you hear a click from the door module when you depress the button? Are the buttons lit? Start by checking out the common problems sticky at the top of this section,
http://www.pontiacbonnevilleclub.com/fo ... 25362.html
scroll down to the interior section until you find: Passenger front and both rear door windows & locks don’t work.
You can also pull the driver's door panel, then check to make sure that all connections to the driver's door module are secure. If so, check for power at the orange wires.
The radio is likely a separate issue. Does the radio display anything at all?
Reller24
Post by Reller24 »
I have checked all fuses, relays and thats about it. The windows son't work at any position. The buttons for the windows and locks are not lit up. There is no noise from any of the buttons also key fob does nothing for locks.
As for the radio, there is nothing lit up on it either, fuses are good.
MikeKerr
Post by MikeKerr »
Think a course of action you may want to consider is isolation, keep the windows and locks issues separate from the radio. Maybe it will all tie together- maybe not.
On the radio- maybe pull it, turn key in accessory position, and see if you have 12 volts coming from the radio wiring harness. If you do- likely bad radio.
For the locks and windows- check every door window and lock separate. If any work (especially the driver lock), let us know and we can help guide the next step. If every lock and window is dead report back and we can suggest another course of action.
Make sure you have a meter, do some isolation via voltage is a good starting point.
jercon51
Year and Trim: 2000 Pontiac Bonneville SE
Post by jercon51 »
check under the drivers seat. a friend of mine was having the same issue and he found some broken wires under the seat. fixed them and then everything started working again. hopefully this helps.
Reller24
Post by Reller24 »
I checked the wires under the seat, no corrision but i got rid of the plastic connector since I had it apart. I have 12 volts at the orange wire in the drivers door at the button module. Still stumped!?!?
Archon
Post by Archon »
Does the power remain on the orange wires when the switch is activated, or does it drop off? Pull the water shield and check to be sure the plug is in the connector to the motor. You may also want to run power directly to the motor to see if it works that way.
chazzei1
Year and Trim: 2002 SE and 2003 SLE
Post by chazzei1 »
Hello everyone!.....wow having a Bonneville again is nice, I have a 2002 SE and a 2003 SLE and really love the comfort and style of these cars.....................I have the same problem with my 2002 SE ...INOP.....DOOR LOCKS...MIRROR ADJ...&...ALL WINDOW SWITCHES...( My Drivers Door has NO POWER) I found this out after a drive around town, and went to the mail box....no power to the window,and realized I had lost any power to any door controls....thanks in advance for your knowledge of a possible common problem, Charlie.....760-264-57one 6 :-)
