Speakers w/ bose audio...
Raviaan
Post by Raviaan »
I am not looking to get into a full blown subs in the trunk system. I am pretty happy with the way my stock system is... I just want a LIL better sound... lil lower bass, and a little more range. What speaker can I use with the bose system? Obviously I have read anything over 2ohms won't really work well... any suggestions?
ray
lglarum
Re: Speakers w/ bose audio...
Post by lglarum »
What year is your car? You could get a decent set of 6x9s for the rear deck and amp them up. Just need an amp with line level inputs or a line level convertor plus an amp. This way you can just come off of the original speaker wires into the amp/line level convertor, then off the amp to the new speakers. If you were to do this and you have a 2000+ you wouldnt need to tear apart the entire interior to run a power wire since you have the battery under the rear seat. That is what I did.
