fuse in battery cable
wast3dd3ath
Year and Trim: 01 se
Post by wast3dd3ath »
I just upgraded my factory alt cable and cable to battery. I noticed there was no fuse on either cable. Is this correct or was it removed before I got the car?
96 SSEi
Re: fuse in battery cable
Post by 96 SSEi »
Hi, is there not a fusable link from the alt to starter? look near the starter.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
wast3dd3ath
Mines a 01 the alt wire went to the fuse box under the hood not the starter. It was a sold red wire, I looked for a link but didn't see one.
There is no in-line fuse on either cable. All the fuses are in both fuse boxes.
wast3dd3ath
So theres no factory protection between alt and battery.
No. The alternator cable and starter cable are on their own harness and connect to the underhood fuse box. The underhood fuse box connects directly to the battery, no fuses inline.
