Which spark plugs?
kennyz
- SSE Member
- Year and Trim: 1994 SE RIP
2000 SSEi - Location: West Greenwich, R.I.
Which spark plugs?
I`ve been told that the proper plug for a 2000 SSEi is an AC Delco 41-101 and an AC Delco 41-121. Which one is the proper one?
- Hans
- Year and Trim: '07 MDX | '13 TL | '06 GTO
Re: Which spark plugs?
Stock AC Delco 41-101 should be fine. NGK are not bad. Avoid Bosch. I'd stick with stock wires, most aftermarkets I've had have been poor quality.kennyz wrote:I`ve been told that the proper plug for a 2000 SSEi is an AC Delco 41-101 and an AC Delco 41-121. Which one is the proper one?
irv
- Year and Trim: 03 sle-white, 39000 miles
01 sle-bronze, - Location: mt morris il
delco also has an iridium plug that is reasonably priced
o3 sle- white-59000 miles
96 cougar-36000 miles
07 mountaineer-67000 miles
i run irridiums in mine.. had coppers but they kept opening up the gap and not running well so i went back to irridiums.
S
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Hello-
Just got a 2003 SE with 94k on it... has anyone ran the e3 spark plug e3.44? What wires work best
- J Wikoff
- Year and Trim: 1992 SSE
In my experience, standard style plugs are less prone to fouling. It also seems to me that a lot of extra ground strap like that would tend to shield the spark from the fuel and create a bit of a disturbance in the propagation of the flame front.
- nos4blood70
Use Iridium for longevity. Avoid platinum, as it doesn't work in waste-spark style ignition systems.
