Air Fuel Ratio at WOT
- 2000Silverbullet
- Retired Gearhead
So refresh my old memory on what the ratio should be to safely run at peak hp?
Stoich is 14.7 and I am seeing max of 10.8 at WOT using the methanol......11.5 under heavy throttle.
What do you others run?
rustyroger
- Posts like an LG3
- Year and Trim: 1998 Buick Park Avenue
Re: Air Fuel Ratio at WOT
A bit richer is normal for WOT operation, particularly with modern adulterated gas. Running lean with methanol can wreck an engine in short order.
Roger.
Roger.
- bobtaz13
- Posts like an LG3
- Year and Trim: 2001 SSEi
1991 SE - Location: Minnesota
I was running 11.1 at WOT, before my last tune. Now it's 12.0 or so.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
- 2000Silverbullet
- Retired Gearhead
Thanks, I was hoping you would chime in....
I must be a little richer due to the addition of methanol in my 50/50 cooling water mix.
Under heavy throttle the A/F is 11.5 - 12.0 but as soon as the juice starts to spray at 8000 hz it drops.
Are those phenolic intercooler plates still available?
- nos4blood70
Looks spot on to me with Meth
- bobtaz13
- Posts like an LG3
This is his new version http://www.ebay.com/itm/121396442528?_t ... EBIDX%3AIT
looks about right to me.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
- 2000Silverbullet
- Retired Gearhead
Auto meter Pro comp
