trans code 1811
irv
- Year and Trim: 03 sle-white, 39000 miles
01 sle-bronze, - Location: mt morris il
trans code 1811
i s this the solenoid code you talk about?
o3 sle- white-59000 miles
96 cougar-36000 miles
07 mountaineer-67000 miles
96 SSEi
- Posts like a Northstar
Re: trans code 1811
HI, please look here for some info on 1811:
http://www.batauto.com/threads/gms-p1811-code.2370/
and here...
http://www.tripleedgeperformance.com/Ha ... P1811.html
and here...
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
irv
Re: trans code 1811
already tried luegard and have dexron 6 in trans. car has 56000 on it.
96 SSEi
Re: trans code 1811
is there a drivability problem that you notice? cant find anything on the forum about this but give more info and someone will tell you for sure+ it keeps the post near the top so easy to find
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
- Archon
Re: trans code 1811
That code is often set when there is a problem with the pressure control solenoid in the transmission. A shift kit often takes care of the harsh shift when warm problem, if that is what you're experiencing. You'll find the information in common problems thread toward the top of this section, under transmission.
irv
Re: trans code 1811
ordered the kit from triple edge. it has had a long shift time from 2-3 quite often. has
done it for the 20,000 miles ive owned it. no residue in the pan.fluid changed at 34000
and at 50000, when i put in dexron 6 and lubegard platinum. will try the kit first and
hope it works. if not the pcs solenoid. will let my mechanic friend handle that.also had a
misfire code. you could feel it at low rpms in od when going up a hill. shift down and you
didnt feel it. put iridium plugs and delco wires on it and replaced coil packs.the misfire
was on cyl 2 and 6 so not on same coil.
thank you much for the help. i forgot to mention i did change the frt motor mount too the other
day. it wasnt completly broken but moved quite a bit.
96 SSEi
Re: trans code 1811
good, lets hope the kit remedies the issue with tranny and your new parts repair missing issue
good luck!!
good luck!!
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
- nos4blood70
Re: trans code 1811
+1 on the shift kit. 99% of the time solves the issue. Did the trick for me.
irv
Re: trans code 1811
got the kit in today. shifts in the .3 -.4 second range.only put
a couple of miles on. will see how it goes. thanks for all the help!!
