Torquing head bolts
bonniebird
Year and Trim: 1998 SE
Torquing head bolts
Post by bonniebird »
98 bonneville 3.8.....we had blown h/g due to radiator failure...so just picked up heads from machine shop...need to know how to torque the head bolts...svc manual states tighten first to 37 ft lbs then rotate 130 degrees using a torque angle meter....we don't have one... Is there any other way or do we need to get that tool?
Many thanks,
Melanie
Re: Torquing head bolts
You don't need it. 130 degrees is about one third of a rotation.
95naSTA
Post by 95naSTA »
Yep, I've never had a problem just eyeing it up on the rotation.
bonniebird
Thanks guys.....went and bought the $10 tool after all because he really wants to be more sure after the last 3weeks dismantling the U im/lim exhaust man and heads etc. don't let anyone tell you this is a no big deal job...some of the various bolts took an hour to get off and that was with pb blaster! I just hope it runs as good as it used to when we get it all buttoned up...
Just make sure all mating surfaces, especially the heads and block, are pristinely clean. You don't want to have a leak.
1oldman
Post by 1oldman »
bonniebird wrote:98 bonneville 3.8.....we had blown h/g due to radiator failure...so just picked up heads from machine shop...need to know how to torque the head bolts...svc manual states tighten first to 37 ft lbs then rotate 130 degrees using a torque angle meter....we don't have one... Is there any other way or do we need to get that tool?
Many thanks,
Melanie
Made my own with cardboard, protractor, and white out - LOL! - BC
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
The tool is the easiest way, but a protractor also works, I would venture so far as to say that by the 4th or 5th bolt you should also be able to feel when the bolt reaches the TTY point.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
