I have searched and searched, but couldn't find much about this. I did check to see if the master cylinder is leaking, and there are no signs of leaks. Also, the emergency light is intermittent, thought as the days go by, it is on more and more (the car also chimes when it pops on).
Based on one post, I unplugged the sensor going into the master cylinder when the light was on, to see if the light would turn off. It stayed on.
Brakes work amazing. Pads and rotors are only weeks old (they were put on after the light problem started), and the car will stop on a dime. I do notice that at a stop, I can press the brake peddle almost to the floor, and I can't recall if this is normal or not. During actual braking, the peddle works normal. I have also noticed at times when braking, that the peddle will vibrate for a split second, almost as if the ABS has been engaged, but the ABS hasn't worked in months due to the wheel bearing speed sensor.
Does this sound like a bad master cylinder?
Any help is greatly appreciated
