Ssei
Jnegrea93
Year and Trim: "00 ssei"
Ssei
Post by Jnegrea93 »
I have a 2000 ssei and I keep getting a code that says small evap leak but I clear it and it will be fine for a few weeks then it pops back on and causes a chek engine light. I was told gas cap but I wanted some input from te club first.
Re: Ssei
I would try and replace the gas cap.
Re: Ssei
Nah, the gas cap is never really the problem. Is there corrosion on the filler neck? If its rusty, try cleaning it up. After that it is probably the purge solenoid or the vent valve.
Jnegrea93
Re: Ssei
Post by Jnegrea93 »
Doe any of that cause bad ha mileage? My gas mileage has dropped a lot lately
Re: Ssei
No not really. When is the last time you had a tune-up? Plugs and wires? Oxygen sensor?
Jnegrea93
Re: Ssei
Post by Jnegrea93 »
Just done and I ran a scan tool and all it says is small evay leak
mrrcom
Year and Trim: 2000 Bonneville SSEI
Re: Ssei
Post by mrrcom »
me and another member are having the same problems. and my new gas cap and cleaned filler neck havent helped any. personally im gonna get a vacuum pump from harbor freight and try and check the line, canister, and valves with it.
Jnegrea93
Re: Ssei
Post by Jnegrea93 »
Let me know what the results are
mrrcom
Re: Ssei
Post by mrrcom »
yup. gonna tackle it today hopefully get this *dang* code gone for good!
i just posted this what i did and found out
http://www.pontiacbonnevilleclub.com/fo ... 44536.html
