P1652 IAC Monitor Disabled by PSP Switch Failed On
anwisdom
Year and Trim: 1998 SSEi
2000 SE
2006 Kia Sportage SE
Post by anwisdom »
Ok, so I got this code (p1652) and I don't really know what it means. :dontknow: Just doing a search on Pontiac Bonneville Club I get results for Fan 2 Relay, but the DTC page(http://www.pontiacbonnevilleclub.com/fo ... ilit=p1652) says it is IAC Monitor Disabled by PSP Switch Failed On.
IAC - idle air controller, got that part.
PSP - purple snuggly porcupine? phoenician swing pusher? power steering pump?
Over all, the code means....?
Archon
Re: P1652 IAC Monitor Disabled by PSP Switch Failed On
Post by Archon »
This is what GM has for 1998 for DTC P1652:
DTC P1652 Cooling Fan Relay 2 Control Circuit.
anwisdom
2000 SE
Post by anwisdom »
Ok, that's one of the things I mentioned that I found. So then what is this? (http://www.pontiacbonnevilleclub.com/f ... ilit=p1652) IAC Monitor Disabled by PSP Switch Failed On
Both fans seem to be working. So unless the control circuit failure does not cause the either fan to cease working, then I don't think that is the issue.
