I see the apn upper intake kit for my moms 2000 park ave, which lower gaskets should i get?
There's 96-08 lower gasket set, with permadryplus. Or 97-05 lower gasket set without permadryplus. Or is there an aluminum lower gasket set that im missing and should buy?
I need to know what you guys get
Datbonneville1
- Year and Trim: 94 pontiac bonneville se
94 buick lesabre
Datbonneville1
94 buick lesabre
Re: I need to know what you guys get
And where would you guys recommend i buy my upper intake/upper gasket set/lower gasket set for my 94 se?
- xxdabroxx
- GXP Member
- Year and Trim: 2001 Bonneville SSEI 32,000 miles bone stock
I'd like to know which are the best as well as this is on my short list.
NEVER INSTALL A PLASTIC GASKET AGAIN.
I have installed the stamped-steel FEL-PRO Part #MS98014T into dozens of cars with success. I like this set because it comes with the RTV.
The GM aluminum ones work great too: ACDELCO Part #89017825
Datbonneville1
94 buick lesabre
Thanks harofreak! Thatll fit a 2000 park ave series II n/a?
Datbonneville1
94 buick lesabre
did my research and it does, haha sorry. Now where can i find the parts/best brands for my 94 series I n/a? Upper intake/upper and lower gasket kit?
